Memory seat/wheel trouble
Old Jul 30, 2012 | 05:24 PM
Boeingtravel95's Avatar
Default Memory seat/wheel trouble
I have a 1997 xj6 and when i get in the car the seat is supposed to be all the way back for easy entry and then move to your desired position when you turn the key...right? Mine stays in the position i set it but when you tuen the ignition off you can hear the seat motor but the seat doesnt move. what could be causing this? Also my wheel doesnt telescope out or in. I can hear the motor but it doesnt move either. tips?
Old Jul 31, 2012 | 07:51 AM
mgb4tim's Avatar
The steering wheel control also rotates. Look at it and turn it to Auto. You hear the motor and the wheel doesn't move in or out, broken shaft. Mine too.
Old Jul 31, 2012 | 08:22 AM
Doug's Avatar
It sounds like whatever the motor "drives" is broken. I'm no help. I can't rememeber if the seats use drive cables, or if the motors are attached directly to gearboxes, or what.
Both the tilt and telescope functions use motors to operate drive cables....which rotate to operate the adjustment mechanisms. The drive cables are known to break.
It used to be that the motors and cables were sold together as a unit. However, Coventry West (and perhaps others) found a supplier for the cables alone....which saves lots of money.
The motor and cable for the "tilt" function is easy to remove and replace. As I recall, though, the same can't be said for the "telescope" motor.
Old Aug 17, 2012 | 07:22 AM
Chris Green's Avatar
Default tilt not working
ok i read the posts but my problem is the tilt don't work, no motor noise nothing so i stuck with it on lowest setting, tryed auto and manual but nothing. is there a way to "wind" it up so i don't struggle to get in the car?
LnrB
Oct 13, 2015 12:45 AM
Newark Nj Gang
Oct 2, 2015 02:39 PM
dpappyp
Sep 29, 2015 01:28 PM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
