Mystery Tube
Old Mar 22, 2013 | 10:37 AM
windsorlad111's Avatar
Default Mystery Tube
Hi all, I was looking at my 96 XJ6 and there is a rubber tube hanging down behind the right rear wheel below the trunk. Looks like it might be a drain tube of some sort, but I am not sure. Any ideas?
Old Mar 22, 2013 | 10:59 AM
FireCrow's Avatar
From memory, yeah, sounds right, I think it's the drain tube wich goes from the antenna, which should be just above it
97x306's Avatar
I believe there are 3 of those; 1 for the power antenna and 2 for the sunroof drain
Old Mar 22, 2013 | 12:12 PM
FireCrow's Avatar
Unless you don't have sunroof, then it leaves only one tube
Old Mar 22, 2013 | 12:28 PM
RJ237's Avatar
What about the battery vent?
Old Mar 22, 2013 | 12:33 PM
FireCrow's Avatar
wouldn't that be lower and closer to the front of the wheel, rather than behind it?
Old Mar 22, 2013 | 04:54 PM
mikesmith2's Avatar
There is also one for the fuel filler recess, I only know because just after I got mine I went for fuel and the recess was full of water.
Found the rubber filter in the corner took it out gave it a good clean and no more swimming pool around the filler neck.
Poet
Feb 7, 2025 02:18 PM
Joachim1167
Nov 7, 2020 09:18 PM
mrplow58
Sep 30, 2015 08:56 AM
caldoofy
Sep 28, 2015 08:43 PM
