Need error code help PLEASE!! P0411
Old Nov 20, 2009 | 10:04 AM
jozepy's Avatar
Question Need error code help PLEASE!! P0411
Hi All & Happy Thanksgiving My check engine light came on in my 1995 XJ6 .. The Error code im getting is P0411 :Secondary air insufficient flow. Any Idea what this means & what part I need to replace to resolve this issue..
Old Nov 21, 2009 | 12:58 PM
tallblondeguy's Avatar
Default vacuum line / electrical line
It's probably a vacuum line issue. Check all your vacuum lines and elect line connections related to the airpump.
C.
Old Nov 21, 2009 | 04:10 PM
Brutal's Avatar
Its not a vacuum issue, there was updated hoses way back when, but theyre no longer avail. You probobly need a new air pump and replace the metal 1 way check valve as these leak exhuast over time and burnup the inside of the pump
Old Nov 22, 2009 | 10:00 AM
jozepy's Avatar
Thank you all so much for your help Is this the 1 way check valve your refering to 1995 Jaguar Air Inject Check Valve :: Also any Idea where I might find it? ( have to learn somehow) I am supposed to drive 1600 mi round trip with it leaving in a few days. Will this hamper the trip or cause futher damage to the car if it turns out the air pump is BAD & needs replaced. Thanks again.
Bcrary3
Feb 21, 2023 04:29 AM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
Jpav27
Sep 26, 2015 03:33 PM
tonyforman
Sep 10, 2015 07:23 PM
