Need help with o2 sensors on a 1996 xj6
Old Apr 27, 2015 | 04:04 PM
adam699's Avatar
Default Need help with o2 sensors on a 1996 xj6
So the car doesn't want to pass emissions.
4 out of the 6 monitors do not want to set.
There is no codes and no check engine light.
I hooked up my autoenginuity scan tool and bank1 sensor 2 appears to give no feedback. Other sensors work fine.
Now with the car running and the live scanner plugged in, I disconnected the plug of the downstream sensor that I suspect is guilty and the value reported by the other one disappeared. So at first I thought that i got them mixed up, but when I plug it back in and disconnect the other one the same thing happens. Are they on the same circuit?
Old Apr 27, 2015 | 06:48 PM
SleekJag12's Avatar
Tell us which 4 monitors won't set? How much have you driven the car? Some of them take several drives to set, like Evap system and O2 efficiency (re: the drive cycle). If they won't set in a "given" time, the CEL should come on, with codes.
Of course you need feedback from all 4 O2s, otherwise several codes could (should) eventually appear. Make sure the connections are good, the O2 plugs fully seated. If you have one dead o2, I suspect that could cause failure of several monitors.
I don't know if continuity between both sensors is required or not, but I tend to "think" not.
Old Apr 27, 2015 | 07:40 PM
adam699's Avatar
The only ones that set are the oxygen sensor monitoring and EGR.
I did more testing today and the dead sensor came to life but only at WOT.
I ordered a new one from Rockauto for $58.
I was reading the service manual and it seemed like all of them could set after a proper drive cycle.
I have several newer jags (2 '98 and 2 '06) and when things are not right the CEL is on right away. With this xj6 it takes forever.
Old May 8, 2015 | 12:23 PM
adam699's Avatar
So I changed the faulty o2 sensor. Reading are now showing. Drove the car for 2 days, city and highway. Went through more than half a gas tank and the monitors still won't set. What's going on? There is no codes and no CEL.
Old May 8, 2015 | 12:59 PM
adam699's Avatar
rusty37
Apr 5, 2020 07:40 PM
KarimPA
Sep 12, 2015 08:15 AM
JimMLiny
Sep 9, 2015 08:13 PM
KarimPA
Sep 3, 2015 07:32 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
