New old user with new old XJ6 Sport! - and a few questions :D
Old Jan 13, 2015 | 02:44 PM
Daim's Avatar
Default New old user with new old XJ6 Sport! - and a few questions :D
Hi there!
I decided to replace my Volvo C30 with an XJ6 Sport... Loving the looks and style but some things need replacing or at least an "overhaul". The headliner is hanging a tad, but nothing wild. Nothing urgent.
Before someone says anything, yes, I know, the XJ6 is a cruiser and no bruiser... But I'd like to lower it. It already is I think 7 mm lower (from factory as it is a "Sport"). But I'd like it a tad lower. Has anyone had any experience with some lowering springs? If so, what ones? All I can find are H&R...
The boot/trunk switch doesn't seem to work. Is it a common problem or is there something which can cause it to fail to work (cracked wires???)?
Otherwise the car is great. Love it to bits! Here a few pics (don't be surprised, we have a few cars and the drive is getting more Jags in it ):
[img]https://farm8.staticflickr.com/7482/16078120650_1aaed9d801_b.jpg[/img
Damien
Old Jan 13, 2015 | 03:03 PM
RJ237's Avatar
Welcome back.
The headliner is a DIY replacement if you are so inclined. Use the search to find some threads with photos.
The trunk lid is often due to a broken wire in the hinge area.
Old Jan 13, 2015 | 03:16 PM
Doug's Avatar
I like it!
Lowering: one thing that needs to be discussed is that the X300s have preset, non-adjustable camber. This might be a problem if you lower the suspension
Old Jan 13, 2015 | 03:38 PM
Daim's Avatar
Originally Posted by RJ237
Welcome back.
Well, not really welcome back I'm more active in the XJ-S section as my other car is - as seen in the pictures - an XJ-S But thanks
Headliner is an easy job. The trunk/boot is more my issue. Mostly a broken wire you say... Is the hinge easy to access or a PITA?
Originally Posted by Doug
I like it!
Cheers Doug! I like it too It is "only" the base 3.2l Sport but enough for my daily needs The lowering issues you state are quite common nowadays. My C30 had a totally inadjustable camber. Only way to do something was to buy different camber arms. I never did and had a really bad negative camber at the rear (though with in the Volvo specs).
Old Jan 13, 2015 | 06:42 PM
RJ237's Avatar
The wire harness alongside the right side hinge is the place to start.
Old Jan 14, 2015 | 10:27 AM
Daim's Avatar
Tried it today... Held the button a tad longer and e voila... It opens. So that is fine...
Old Jan 14, 2015 | 08:03 PM
al_roethlisberger's Avatar
Ah hah, see, I knew some of the XJR/Sport interiors had the rear cigar lighter stock!
You can see my quest to find that part here:
https://www.jaguarforums.com/forum/x...ighter-123392/
Also, should all X300s have that "tool kit" under the engine compartment fuse block door? I don't have one of those kits (USA spec XJR). Is mine lost, or did NA/USA spec cars never have that kit?
Old Jan 14, 2015 | 08:07 PM
Doug's Avatar
USA cars didn't have the tool kit
Old Jan 14, 2015 | 08:28 PM
Compounder's Avatar
My 96 XJR does.
Old Jan 14, 2015 | 08:45 PM
.... another Jaguar mystery
Although humorously, not really sure what that assortment of bulbs and "tools" is really supposed to accomplish other than just that, changing a fuse/bulb
Sharp looking car BTW!
Old Jan 14, 2015 | 08:47 PM
Doug's Avatar
Just proves....whenever you say something in absolute terms an exception always comes along! I should know better
Might be fun to hear from others on this
Old Jan 16, 2015 | 01:21 AM
jagent's Avatar
The Sport (in our market at least) didn't come with the tool kit. As I'm sure many other owners have done, I've put together what I believe to be a more useful kit than the stock Jaguar issue and it fits snuggly in the cubby.
Old Jan 16, 2015 | 02:43 AM
Daim's Avatar
Here the sport gets the tool kit from factory... Or better got it
Old Jan 16, 2015 | 08:53 AM
countyjag's Avatar
Re the boot switch, does the boot release ok from the switch in the dash? If so, the most likely culprit is the microswitch behind the button on the boot lid. The dealers sold "dozens" of these button/switch assemblies back in the day, and they are still available new for £65 ish. ebay has used ones between £10 and £20, but if you can use a soldering iron, replace just the microswitch, which is a common microswitch size. A very simple job, and very obvious what to do when you have the button off the bootlid, which is a 15 minute job. Cost me £2.49 from Maplins for the switch.
If the dashboard switch doesn't release the bootlid, it may point to a wiring fault at the hinge, but I bet it does work.
Old Jan 16, 2015 | 10:00 AM
Daim's Avatar
All works again mate... The dash switch as well as the boot switch. I just didn't press the switch long enough
Old Jan 17, 2015 | 09:49 AM
weisberg's Avatar
What? No sport button on the Sport model? I like the growler button though.
Did Sports always come with the PowerLok LSD the XJR did?
I drive my XJ6 in a very sporty manner, I have to wonder what the LSD feels like going back and forth on tight turns.
Great pics. Adding those to my screen saver.
Old Jan 17, 2015 | 09:54 AM
Daim's Avatar
No sport button, because it is the "low end" ZF tranny. No electrical operations in it... If it was the 4.0l it would have it (I have been told).
I haven't had a chance to test if it has an LSD. Would be nice if it did
Old Jan 17, 2015 | 10:03 AM
weisberg's Avatar
My XJ6 4.0 litre had an amusing oversteer trait in stock trim. Yours likely much tighter, so while we both get beaten by newer Toyota Camry V6 in a straight line, you can still have lots of fun taking turns quickly.
Old Jan 17, 2015 | 10:22 AM
Daim's Avatar
Luckily they don't sell Camrys here
Old Jan 23, 2015 | 02:12 AM
Daim's Avatar
Well then... It's totaled... Hit a patch of ice at a lower speed (~45 kmh so about 30 mph), spun left, spun right and slid into a garden killing a street sign, some trees and ended up smashing into a tree with my drivers door...
