Noisy air pump
Old Nov 20, 2008 | 05:21 AM
biffta's Avatar
Default Noisy air pump
In another post I queried a whining noise from the engine. I have now found it to be coming from the air pump as the noise goes when I disconnect the electrical connection to it.
From what I have researched, it seems the unit is activated during warm up to reduce emissions.
I have two questions:-
1. Is any harm done to the car if I disconnect the unit?
2. Can the unit be 'serviced' in any way?
Thanks in advance
Old Nov 20, 2008 | 12:31 PM
ken@britishparts.com's Avatar
Default RE: Noisy air pump
Replace it. I have new ones for $150.43.
Old Nov 20, 2008 | 02:55 PM
Brutal's Avatar
UH, IF IT STOPS WHINNING WHEN HOOKED UP YOU NEED TO REPLACE IT, THATS HOW I TELL IF THEYRE WORKING, START THE CAR AND LISTEN FOR THE WHINE. AND YES YOU NEED IT, AND YES YOULL SET A CHECK ENGINE LIGHT WITHOUT IT OR IF LEFT UNPLUGGED, AND NO YOU CANT SERVICE IT, BUT YOU CAN BREAK OPEN THE PLASTIC HOUSING AND LOOK INSIDE BEFORE YOU THROW IT AWAY
dsnyder586
Dec 29, 2024 07:39 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1964Daimler
Sep 9, 2015 11:28 AM
