Oil pressure gauge reads zero, oil light is on(1996 Jaguar xj6 VP)
Old Jun 9, 2023 | 05:56 PM
LaggyJaggy's Avatar
Default Oil pressure gauge reads zero, oil light is on(1996 Jaguar xj6 VP)
Long story short 3 of my spark plugs had hella oil on them so I took off and replaced the valve gaskets n o rings. Since I did that I also jus did an oil change and replaced the oil filter. Now my oil pressure gauge reads at zero and the oil light is on.
There are no visible leaks anywhere around the gasket nor are there any leaks around the oil filter. I used the same oil as before so idk what’s going on please help
i also replaced all of the spark plugs and ignition coils
Old Jun 9, 2023 | 06:37 PM
Parker 7's Avatar
Right by the oil filter is the pressure sender that is a push on connection if I remember correctly
I think it is single wire
It is located slightly above and aft of the oil filter housing block and has to be got from the bottom, but you can try from the top
Genuine Engine Assembly-3.2/4.0 Litre (3.2 Litre,4.0 Litre,4.0 Litre (california),4.0 Litre Supercharged) For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
And see item # 11
Genuine Oil Filter-3.2/4.0 Litre For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
jomo
Nov 22, 2021 09:01 PM
Woznaldo
Nov 5, 2012 07:49 AM
XJ6 Continental
General Tech Help
Sep 23, 2012 01:42 PM
shoeboy
XJ40 ( XJ81 )
Jan 29, 2012 03:17 AM
rolexmike
XJ40 ( XJ81 )
Feb 28, 2011 08:59 AM
