one sick cat with srs light on
Old Jun 13, 2013 | 11:37 PM
Paul Obraczka's Avatar
Default one sick cat with srs light on
the jag 1995 vps has no flashing code when you do the ignition on mode ....no light for about 10 secs that the lights pops on ....any ideas ? thxs
Old Jun 14, 2013 | 01:26 AM
mikesmith2's Avatar
Check the connections under the seat to the seat belt pretensioners.
Old Jun 14, 2013 | 08:02 AM
Doug's Avatar
I've had only one go-round with the SRS. Not having a scan tool that reads SRS codes or any other test equipment I was left with just checking grounds and connectors. No help.
I spotted an air bag module on Ebay for about $35. Considering a jaunt to the Jag dealer is a 120+ mile proposition, a wasted day, and minimum $120 service charge just to read the codes, the $35 used module started looking rather attractive.
I bought it, installed it....and the SRS went away !
Pure luck.
Hopefully you'll have the same.
Old Jun 14, 2013 | 08:04 AM
Doug's Avatar
We have pretensioners on out old X300s? Really? I had no idea.
Old Jun 16, 2013 | 09:32 PM
Default srs light ?
which code reader is the best for job ? obd 2 i have .....thxs
Old Jun 16, 2013 | 10:48 PM
Tirefriar's Avatar
when seat belt buckles start wearing out, they tend to send a code. the amateur readers sold for a few hundred bucks are not going to read the code to the point of isolating the source. the computer that can read what you need costs thousands and is usually in use by pros. check with a local dealer on how much they would charge for a diagnostic or contact an independent jag shop. locating the source will save you frustration and money
Old Jun 17, 2013 | 08:36 AM
motorcarman's Avatar
There are no flash codes on early cars. PDU, WDS, IDS, SDD AutoEnginuity etc. can read all the modules from OBDII Jaguars. Only PDU or JDS are used on the OBDI cars.
bob gauff
Aus V8S
Nov 13, 2015 11:01 AM
neruda
Oct 18, 2015 01:19 PM
mrplow58
Sep 9, 2015 11:27 AM
02jagstype
Sep 4, 2015 08:20 PM
rachelstr
Sep 3, 2015 12:59 PM
