Peanut Buttery Oil
Old Jan 15, 2011 | 09:06 PM
TopHatChef's Avatar
Default Peanut Buttery Oil
Well, after reading all of the recent threads one here about oil, I went and checked my oil. I checked the oil with a cold engine. There was just a bit on the dip stick, about a centimeter (at that), and had a slight tinge of peanut butter colored streak in it. I dipped and checked the stick several times, each revealing slightly less peanut butter (for lack of a better word). What could that be?
I've never really worried about checking my oil. I don't know if it's low or anything. I just check for color, and make sure there are no bits in it (I always change my oil on what I feel like is a good interval). It's currently been 3-4 thousand miles since my last oil change. The car isn't and hasn't been leaking any oil (at least visibly).
Old Jan 15, 2011 | 10:08 PM
Doug's Avatar
A bit of emulsification, I'll wager. No worries. Take 'er on a good highway run for an hour and re-check.
Old Jan 15, 2011 | 10:18 PM
Miroxz's Avatar
didnt know that!....was gonna state the usual oil/water mixing symptom
Old Jan 15, 2011 | 10:48 PM
Doug's Avatar
And you'd be right.
Condensation often develops on dipsticks or other areas...inside oil caps, etc....when there hasn't been enough heat to evaporate it away. Pretty common, really, especially if the car is unused for a few days and /or used just for short trips.
Old Jan 16, 2011 | 08:13 PM
TopHatChef's Avatar
Yeah, however, my car is driven every day, and it's usually a good 15 minute trip (at the least), defiantly enough to get the oil up to operating temp. Just in case, I'll check the oil when the engine is warm, and hopefully that will be it.
Old Jan 16, 2011 | 08:42 PM
Doug's Avatar
15 minutes is not enough. Take it on a good run for an hour.
Old Jan 16, 2011 | 09:15 PM
TopHatChef's Avatar
I suppose I'll go for a nice little drive down the coast after a nice detail tomorrow or Tuesday.
MrWhite
19
Jun 14, 2022 07:49 PM
3jagfamily
Oct 1, 2015 01:49 AM
42Ajd
Sep 26, 2015 07:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
