Possible vacuum leak? '97 XJ6R
Old Oct 1, 2023 | 05:16 PM
jagstuart's Avatar
Unhappy Possible vacuum leak? '97 XJ6R
Could this be a possible vacuum leak or at very least a concern?
Old Oct 1, 2023 | 08:03 PM
Doug's Avatar
Look at the illustration below. You want to ensure a good seal at item #6 and #8
https://parts.jaguarlandroverclassic.../brand/jaguar/
The big body of the duct shouldn't be loose, no. But in and of itself that looseness won't cause an air leak
Old Oct 3, 2023 | 12:47 PM
Larry Louton's Avatar
Hello, As all the pipework is down stream of the air flow meter, any joint leak is unwanted, unmeasured air. A smoke tester connected to the hose for the fuel pressure regulator and the air flow meter removed and capped off will reveal very quickly if you have a leak any where. You can do the exhaust quickly the same way by plugging up the extra tailpipe and forcing the smoke upstream to reveal any cracked exhaust manifolds.
Thank you
Larry Louton
Old Oct 3, 2023 | 04:24 PM
countyjag's Avatar
They all do that, to coin a phrase. If there was a vacuum leak your idle would vary as you moved it. It didn’t flicker. The method of attachment leaves a little play if I remember correctly.
Old Oct 3, 2023 | 07:17 PM
Hello countyjag, let me see wiggle the exhaust to reveal a cracked exhaust manifold. I own a heavily reworked 1985 Jaguar Sovereign with a 1995 XJR6 engine and a GM E460L transmission behind it.. Gold box fuel and ignition system. The component that is being wiggled is held by a few rubber grommets. It's only a matter of time.
Thank you
Larry Louton
Old Oct 4, 2023 | 03:43 AM
countyjag's Avatar
The cracked exhaust manifold issue doesn’t involve a loss of vacuum as such. The cracks allow oxygen to be ingested between exhaust pulses which cause the oxygen sensors to believe the mixture is weak, and lead to it being enriched incorrectly. Car can actually run quite sweetly, but fuel economy deteriorates markedly.
Old Oct 4, 2023 | 07:26 PM
jagstuart's Avatar
I've installed headers. Cigar style smoke detector revealed nothing. Rebuilt coil sub-harness. New filter, plugs, coils, fuel regulator, MAF cleaned. Still has rough idle.
May try new O2 sensors next.
Old Oct 4, 2023 | 08:01 PM
Parker 7's Avatar
With new coils they would still be suspect as some based on manufacture can be bad out of stock or shortly after use
Is there a cylinder code that can be followed if coils swapped positions ?
There are some clean - ups before putting in new O2 sensors which appear lately hard to find in stock
Cameron24
Jun 27, 2021 05:08 AM
2004jaguarxtype
Mar 3, 2015 06:30 AM
e21pilot
Apr 22, 2014 06:42 AM
RonaldP
Aug 1, 2013 11:17 AM
e21pilot
Apr 9, 2010 06:48 AM
