Problem with ABS during bleeding
Old Jun 22, 2020 | 01:45 PM
Rudy Mensink's Avatar
Default Problem with ABS during bleeding
Hello Jaguar-lovers;
After fixing a brake-problem I have to renew the brake fluid on all wheels.
All works fine except for the right front-wheel: it turns out that the brake-fluid does not pass one of the ABS-module outlet-ports: see pictures.
What do you think it can be ? Is it perhaps some dirt in one of the valves?And what do you think, can i try to put somme pressured-air on the outlet port?
Many thanks in advance, greetings, Rudy
Old Jun 22, 2020 | 03:52 PM
Parker 2's Avatar
X300 ? 1994.5 - 1997
See page 222 and 248 of the very large doc link below
http://www.jaguarclub.sk/service/x300.pdf
and item # 2 below
https://parts.jaguarlandroverclassic.com/parts/index/part/id/C50.C5058.C5058290.C50582905347/brand/jaguar/
Conscious pressure valve
Old Jun 23, 2020 | 12:32 PM
Thanks for your support, greatly appriciated!
In my opinion are the fluidlines normally open and should all the outletports bleed when then brakepedal is pressed down, i look further, and let you know.
Tanks, Rudy
Gophat
Sep 17, 2022 03:05 PM
Aincite
Sep 18, 2019 08:25 AM
ufoz8mycow
Oct 19, 2011 01:32 PM
mbalce
Oct 29, 2009 11:34 PM
oldmots
Aug 6, 2008 01:02 PM
