Problem with trunk actuator
Old May 23, 2010 | 06:10 PM
jimp's Avatar
Default Problem with trunk actuator
I am having an issue with the electronic trunk release. Once it is activated it does not return to the locked positon and the trunk won't latch closed. Is it normal for the arm to return to the extended postion automaticaly or is there suposed to be an external spring that causes this?
Thanks,
-Jim
Old May 23, 2010 | 08:04 PM
Gus's Avatar
Gus
I do not know the year of your car; however, the 1995 xj6 had a TSB 76-101 the release button sticking
Old May 23, 2010 | 11:10 PM
jimp's Avatar
it's a 96. The problem isn't with the button as I can manually extend the actuator.
mbergen
Oct 23, 2019 10:26 PM
GordoCatCar
Jan 2, 2017 01:10 PM
martybmw
Apr 2, 2016 04:55 AM
XJsc-guy
Nov 23, 2015 01:56 PM
WinterJag
16
Oct 9, 2015 07:49 PM
