Rad light stays on all the time
Old Oct 24, 2010 | 02:55 PM
Simprof's Avatar
Default Rad light stays on all the time
The Icon at the bottom right side stays on all the time the system is full of water so I was wondering where the sensor for it is located.
It's a 1997 XJR 6 cylinder...Thanks
Old Oct 24, 2010 | 03:22 PM
QuadManiac's Avatar
You're in the wrong forum; this is '98+ XJ8/XJR - probably get much better response in the correct XJ6 one.
Old Oct 24, 2010 | 07:51 PM
Simprof's Avatar
Don't see a XJ6 for a 1997 on the forum
Old Oct 24, 2010 | 08:57 PM
JaguarXJR02's Avatar
you want the X300 forum I think
Old Oct 24, 2010 | 09:03 PM
harrymitch's Avatar
need to program new key to car
Old Oct 24, 2010 | 09:04 PM
harrymitch's Avatar
2008 xjr coupe
Old Oct 25, 2010 | 01:30 AM
QuadManiac's Avatar
Your car is an X300 series, so that is your forum... the 98+ XJ's are X308's.
Old Oct 25, 2010 | 01:31 AM
QuadManiac's Avatar
You need to start a new thread, not hijack on the end of an existing, unrelated one.
Old Oct 25, 2010 | 03:32 AM
Cadillac's Avatar
Ok,that's moved to the proper forum
Old Oct 25, 2010 | 07:24 PM
TopHatChef's Avatar
Well, after reading through all of the above filth, I have an answer to the original question! On the far side, partially underneath the reservoir for the coolant, is where the sensor 'should' be. If it has fallen out (which is quite a possibility), the sensor is very thin, white/off white, 2-3 inches long. I also believe that it has an orange base. If it's not in the reservoir, hopefully you can find it.
Old Oct 26, 2010 | 08:56 AM
Simprof's Avatar
Thumbs up Thank you Tophatchef
I agree with you all I wanted to know was about a light and all I got from most was "YOUR IN THE WRONG PART OF THE FORUM" I guess some people need to get a life.. lol
Thanks again for you help..
Bill
Old Oct 26, 2010 | 09:09 AM
Turftech's Avatar
Just be careful removing the sensor! It can be ****ly. Check the wiring connection first of course. Then I would pull the expansion tank off and work it out with care. I had one where the plastic covering came loose and just needed to be dried and glued on again.
Cheers!
Old Oct 26, 2010 | 09:13 AM
Turftech's Avatar
Wow. It censored a harmless word! Rhymes with wiggly and starts with an "N".
Cheers!
Shawn Svacha
Nov 4, 2019 02:47 PM
Beardy
Sep 18, 2015 10:00 AM
tberg
Sep 7, 2015 07:32 AM
dcvickers
Sep 2, 2015 06:14 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
