Radiator end caps
Old Jun 21, 2019 | 05:28 PM
1997Sovereign's Avatar
Default Radiator end caps
Hello,anybody have a lead on the replacement end caps for the radiator,looking for the right side or top hose side? Thanks
They seem to be scarce.
Old Jun 22, 2019 | 03:03 AM
SleekJag12's Avatar
Are you are talking about the rubber radiator mounts at the corners, part #11?
Part #11, MNA4241AB Radiator mount. Uro parts makes replacements. Ebay has some.
You will need 4 total, the lowers are shot too.
Old Jun 22, 2019 | 10:45 AM
Hello,no the end cap or tank would be the part that is attached to the sides of the radiator core,where the top hose connects to.
They are held in place with the crimps and have an O ring that seals.
They are replaceable verses replacing the entire radiator,it’s a $125 repair verses a $400 radiator replacement.
They used to be commonly found but seem to be getting hard to find now.
I was on the highway,thermostat must of stuck and built up pressure and blew the neck where the hose connects off.
They are commonly replaced of other cars mostly because of cracking.
westway
21
Nov 16, 2019 01:44 PM
abgwin
Dec 4, 2018 08:19 PM
Kariblay
Jun 30, 2018 08:47 AM
Spillwaybob
Oct 7, 2013 01:01 PM
Spedracr15
May 24, 2011 06:08 PM
