Intake manifold vacuum port/line
Old 02-06-2018, 02:00 PM
katar83's Avatar
Default Intake manifold vacuum port/line
My car started misfiring on my way back from work today but it wasn't bad enough to stop me. I eventually got home, lifted the bonnet and found an air leak from a vacuum port in the intake manifold, just behind the fuel pressure regulator. Is this normally capped and I just lost a cap or is there a line missing there that should go somewhere? I couldn't find any and just taped it for now, idle is back to normal.
Old 02-06-2018, 02:14 PM
Lady Penelope's Avatar
Received 1,383 Likes on 1,087 Posts
The short line goes from the intake manifold to the fuel pressure regulator . The fuel pressure on the fuel rail is at 43 psi at idle and increases up to about 47 on throttle up from the increased vacuum . You can find the line at the local auto parts store .
Old 02-06-2018, 02:46 PM
katar83's Avatar
There is actually two vacuum ports there, the one on the left(closer to the front of the car) is indeed going to the fuel pressure regulator and the line is still there plugged in ok.
There is however a second one next to it(literally an inch away to the right) and this is the one I'm not sure about and that caused the air leak.
Old 02-06-2018, 05:45 PM
Will have to look at mine as I did not notice .
Old 02-06-2018, 07:49 PM
Yes mine is capped off at the nipple just fwd of the fuel pressure regulator intake manifold nipple . Looks like a factory cap . Might have something to do with the fuel EVAP system as there are 2 different versions on the X300 . Early version has 2 square canisters and other different devices and the later version has 1 minus the other devises . You can look under the car without jacking fwd of the rear wheel on the left and right side . Mine has only 1 on the left side , VIN # 755xxx
katar83 (02-07-2018)
aholbro1
07-14-2022 03:27 PM
MK2
08-05-2017 11:53 AM
jeremiahjaguar
12-02-2013 04:04 PM
xjrwithproblems
10-20-2011 11:58 PM
Steve W
XJ40 ( XJ81 )
10-18-2011 12:23 PM
Quick Reply: Intake manifold vacuum port/line
