Rear Diff. Fluid question
Old May 8, 2008 | 10:16 PM
Jaybo242000's Avatar
Default Rear Diff. Fluid question
Hey folks-
Just a quick question about gear oil. My 96 XJ6 calls for sae 90 oil in the rear end, does that mean that 75/90 would work just fine, logic would tell me yes, but I just want to be sure before I do this, if not, I'll just get some 90 weight, but I would have to believe that 75/90 would work just as well. Any help would be greatly appreciated, thanks everybody, in advance.
-James
Old May 9, 2008 | 10:04 AM
ken@britishparts.com's Avatar
Default RE: Rear Diff. Fluid question
I would go with the straight 90. These diffs are prone to bearing failure. Maybe if you were up North go with the other, but I would stick with the thicker stuff.
Old Feb 3, 2010 | 07:28 PM
panchostatus's Avatar
think I could get away with using lucas 80w-90?
had the differential replaced a little over two years ago, and am in a "tropical", i.e. crazy humid, southern climate.
Old Feb 4, 2010 | 12:42 PM
also a second thought,
anyone have any snazzy solutions for removing a stubborn diff. drain plug?
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Busa R
Sep 3, 2015 05:01 PM
