rear door switch
how do i reach an intermittent rear door switch in a 1995 jaguar vanden plas? also how do i fix an intermittent rear door switch? Thanks for your help.
so i took the door panel off and have narrowed it down to a loose wire that is causing the intermittent door switch. unfortonetly i couldnt reach the loose wire connect without taking the door switch out. How do i take the actual door switch out so i can fix the bad connection? Thanks
99xk8guy
Sep 29, 2025 10:51 PM
