Removing Rear Side Marker Lights
Old May 1, 2012 | 08:16 PM
XJ6Aficionado's Avatar
Default Removing Rear Side Marker Lights
Can someone enlighten me on how to remove the rear side marker lights? The light bulbs in them appear to have blown out and I'd like to replace them.
I am, of course referring to the small rectangular lights with the red lenses that fit in the rear bumper around the right and left sides. There must be a technique for popping them out from the front.
Thanks everybody,
Carl
Old May 1, 2012 | 08:30 PM
Doug's Avatar
Not sure how to remove the entire lamp. If you just wanna replace bulbs then the socket comes out from behind....just reach up in there with your hand....a twist-n-turn type socket as I recall
Old May 2, 2012 | 07:09 AM
sharay38's Avatar
Here's the page from the owner's manual. But it might just be easier to reach up under the bumper.
Old May 3, 2012 | 07:36 PM
Thank you Doug and Sharay for helping me with this.
Carl
Old May 4, 2012 | 12:27 PM
sharay38's Avatar
Carl
No problem. That's why we gather here.
Old Oct 29, 2017 | 08:14 AM
Kevinxj6l1996's Avatar
Default corroded marker light
Hi, does anybody know the part numbers for the marker light plug and wiring harness? Or where to get them? Are they off the shelf at the parts store?
Old Oct 29, 2017 | 11:18 AM
Lady Penelope's Avatar
Do they look like this ?
I looked at mine and they are available at the auto parts store as a EV1 connector same ones used all over the engine and truck dome lights that can be borrowed . Aside from that connector the 90 degree base looses contact with the bulb and the bulbs wire loops can be bent out to make better contact . Also the square connector a foot or so inward from the connector in the pic gets corroded .
http://www.autozone.com/fuel-deliver...artNumber=true
Attached Thumbnails Removing Rear Side Marker Lights-x300-auto-font-b-connector-b-font-font-b-fuel-b-font-font-b-injector-b-font.jpg
BrentGardner
29
Dec 16, 2024 12:13 AM
frujag
Sep 1, 2015 03:43 PM
tonydbaker
Aug 30, 2015 11:02 PM
Doug Dooren
Aug 30, 2015 08:51 AM
rwoodlin
Aug 29, 2015 04:32 PM
