Removing wiper motor
Old Jan 2, 2015 | 02:22 PM
theJPster's Avatar
Default Removing wiper motor
So while cleaning under my lower windscreen cover, I managed to lose the bung for the unused wiper motor hole down inside the cavity.
How on earth do you get to the bottom three bolts to get the wiper motor off? Can it be done without taking the fuel rail and intake off?
PS: It is, at least, pretty solid under that cover. Not even any surface rust.
Old Jan 3, 2015 | 03:42 PM
b1mcp's Avatar
See this post for some tips
https://www.jaguarforums.com/forum/x...r-fail-120179/
Old Jan 4, 2015 | 11:23 PM
journeyman's Avatar
The three bolts along the bottom remain in place. There are sliding clips built onto the wiper assembly that engage the bolts. If I recall correctly - looking at the assembly from the front of the car, the left and center clips slide to the left and the right clip slides to the right. I had to work by feel because I couldn't see what I was doing.
johndahlheimer
Sep 17, 2020 03:10 PM
1LowCat
Feb 23, 2016 07:19 AM
Safari
US Central
Sep 21, 2015 09:34 AM
Saturbo
Sep 8, 2015 07:35 PM
XJsc-guy
Sep 2, 2015 11:43 AM
