Replaced the pump but it won't idle
Old Jul 20, 2019 | 02:08 AM
drewdog's Avatar
Default Replaced the pump but it won't idle
My 1996 XJ6 has been sitting for about a year due to fuel pump issues. I have finally gotten the time to deal with it...so far I replaced the pump
but it won't idle so I change the air idle valve and the crank sensor but still no luck. I had a set of after market coils which I installed with new plugs
but same problem.....help
Old Jul 20, 2019 | 02:29 AM
Welcome to the forum Lenny,
I've moved this post from your Intro thread for advice from members with the same model.
Old Jul 20, 2019 | 07:44 AM
Lady Penelope's Avatar
If the issue was truly the fuel pump and was replaced as the fuel pump fails it will damage the fuel pump relay
Causing arching of the power contacts in the relay it will not carry the proper current for a new pump motor
You can swap it with the Acc relay which is the inboard most relay in the trunk
The pins and sockets on the connector at the pump motor itself can also get burnt
Fuel injector cleaner ?
Old fuel in the tank ?
GAJagStype2004
28
Sep 22, 2017 11:04 PM
kmeseck
Sep 13, 2017 09:25 AM
likica
Jun 4, 2015 06:07 PM
Xcellr8
May 24, 2014 12:30 PM
nthimis
Apr 27, 2013 10:17 AM
