Replacing Fuel Tank Sensor
Old Sep 2, 2011 | 02:59 PM
EZDriver's Avatar
Smile Replacing Fuel Tank Sensor
Finally getting around to replacing the sensor in the fuel tank. Got the level down to around five gallons. Only question is do I need to use a sealant on the rubber gasket or use it dry. Having a fuel leak would not be fun.
EZDriver 1995 XJ6
Old Sep 2, 2011 | 03:33 PM
caldercay's Avatar
EZDriver 1995 XJ6
The Rule Of Thumb for rubber gaskets is to use them dry.
But maybe someone else has something to say in contradiction in this scenario.
Old Sep 2, 2011 | 03:52 PM
Doug's Avatar
No sealer or gasket cement.
Most install them dry. Personally, I give it misting of aerosol silicone so that when the retainer turns against the seal it (the retainer) will slide, not grab.....reducing the (already slim) chance of tearing it or shifting it out of place.
Old Sep 2, 2011 | 06:30 PM
Simprof's Avatar
I'd leave it dry putting anything on it to make the ring slide will tend to push the rubber seal outwards. Rule of thumb if it's rubber leave it dry know matter were you are using it..
fast40driver
Apr 19, 2024 07:24 AM
Stoney85
Jun 10, 2021 09:14 PM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
kenatofc
Oct 27, 2015 06:48 AM
bluerdg
Sep 1, 2015 08:07 AM
