replacing power steering pump
Old May 15, 2012 | 01:36 PM
jhxj6's Avatar
Default replacing power steering pump
Hi, I was wondering if anyone has replaced their power steering pump themselves. I am planning on getting to it within the week and just wanted to know if it was pretty straightforward as it seems or if theres anything I need to look out for, other things that need replacing when you replace the pump, or just anything i might need to know before I get to it. Thanks in advance
Old May 15, 2012 | 03:40 PM
Roger95's Avatar
I strongly suggest getting your replacement pump with the adapter fitted (Coventry West) rather than the pump only (Rock Auto). That adapter can be a b***h to fit...
Remove the heat shield from the exhaust manifold and the rest of the job is a snap. Be mindfull of the plastic union that will fall on the garage floor when you remove the old pump - you need to use that with your new pump.
My instructions are for the AJ16 X300.
rusty37
Jun 7, 2016 04:43 PM
Xj812
Oct 26, 2015 05:04 AM
Mac Allan
Oct 12, 2015 11:59 AM
NTL1991
XJ40 ( XJ81 )
Sep 24, 2015 09:09 PM
jagy4321
Sep 3, 2015 07:56 PM
