RH indicators suddenly stopped working
Old Mar 29, 2024 | 04:56 PM
gibbon's Avatar
Default RH indicators suddenly stopped working
Hi.
All the indicators on the RH side suddenly stopped working. No bulb failure light on dash. Checked all bulbs and they are fine. Checked the fuse in the RH kick board box. Swapped the rear light control module with another one and still the same.
LH is fine. Only LH works when the hazard switch is on.
Any ideas what could be causing this.
Also at the same time the electric arial stopped going up when the radio is switched on.
Ian
Old Mar 30, 2024 | 08:08 PM
Parker 7's Avatar
The turn signal switch stalk has a history of the wires coming off
With the hazard switch ......................
What is your last 6 VIN #s as there was some changes in external lights
7xxxxx
There is a fuse in the trunk for the ariel . # 8 / 15 amp
Old Mar 31, 2024 | 03:33 PM
gibbon's Avatar
I swapped my light control module located in the trunk with a friends X300 and it is working correctly.
I removed the indicator stalk from the steering wheel and checked the soldered joints, all ok. Gave it a liberal spray of contact cleaner. Still no success.
Next is to check the Body process module connections , which i think is located under the glove box.
The # 8 fuse is ok for the arial. I took it apart, and the motor works. The arial goes up and down by applying 12 volts to red and black motor wires.
Old Mar 31, 2024 | 07:37 PM
Parker 7's Avatar
Before you do that there should be something easier
" I swapped my light control module located in the trunk with a friends X300 and it is working correctly. "
looking for input wire / pin to the light control module to prove getting command
To get the arial to move it receives a low current ground by the stereo head at pin 5
Old Apr 1, 2024 | 12:59 AM
Parker 7's Avatar
Turn signal change after 739427
Pin BT21 - 5 Yellow / Blue wire input to lamp module
First
Fuse # 13 / 10 amp right heelboard fuse box
There is a TSB on fuse uprings
15-16 Fuses – Ratings_Circuits.pdf (jagrepair.com)
See page 21 as this connector pin map is the module side and not the removed connector side
jagxj1996.pdf (jagrepair.com)
kevan.s
Mar 14, 2024 04:20 PM
alabbasi
XJ40 ( XJ81 )
Apr 15, 2023 10:55 AM
Leroye1
Nov 1, 2022 08:00 AM
rgcurrin
Jun 27, 2022 12:40 PM
lecuming
May 9, 2011 11:45 AM
