Right Brake Light Always On With Parking Lamps
Old 10-04-2014, 06:53 PM
NTL1991's Avatar
Default Right Brake Light Always On With Parking Lamps
Hello,
I've noticed that when stepping on the brake, my bulb failure indicator always illuminates on my '96 XJ12.
Looking at the outside of the car, it appears that whenever the parking lamps are on (either from the security system flashing them, or actually turning the parking lamps or headlamps on via the switch) my Right hand brake lamp is illuminated brightly, instead of just the parking lamp filament of the bulb being lit, like it should.
I've replaced the Lamp Control Module with a known-good unit and it still happens. I've obviously replaced the bulb, too.
Any ideas?
Thanks,
Nick
Old 10-14-2014, 11:40 PM
NTL1991's Avatar
Turns out I made the same mistake the previous owner made.
Installed the bulb backwards, meaning it was 180 degrees off. I just stupidly assumed it could be installed either way.
My Jag mechanic figured it out in about 5 minutes. This is after I swapped out LCM's, and even scored a Security Module from Pick-and-Pull. I was even thinking maybe the traces in the bulb holder could've been bad...
Either way, no more bulb failure lamp on the cluster, so I'm happy.
-Nick
Old 10-17-2014, 12:39 PM
Atco's Avatar
The twin filament lamp should have offset pins which should prevent incorrect fitting but they are available with the pins not off set making it easier to install the wrong way round. Saying that the non offset lamp would not easily install in an offset lamp holder.
Jpav27
07-31-2022 06:43 AM
afterburner1
12-16-2015 12:12 AM
Dymaxxion
09-04-2015 02:40 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: Right Brake Light Always On With Parking Lamps
