Secondary Air Injection Pump
Old Mar 29, 2019 | 08:22 PM
annamiata's Avatar
Default Secondary Air Injection Pump
I just bought a used Secondary Air Injection Pump and it has exact same pitch noise issue. Can someone explain why X300 Secondary Air Injection Pump has three input wires instead of two input wires like any other Secondary Air Injection Pumps? I am think of making a bracket and uses Secondary Air Injection Pump from later jaguars.
Old Mar 29, 2019 | 08:52 PM
Lady Penelope's Avatar
The weird symbol at pin 1 is a air check valve solenoid inside the pump assembly
Took an X300's apart once as was not running , somehow water had gotten in there rusting it frozen
Referencing the parts catalog they have gone through a couple of part # changes and a TSB on uprating the fuse size
http://www.jagrepair.com/images/TSB/...ion%20Pump.pdf
and
http://www.jagrepair.com/images/TSB/...AIR%20Flow.pdf
See page 46 and 92 - 95 below
http://www.jagrepair.com/images/Trai...20-%202000.pdf
davealberta
21
Dec 9, 2022 08:54 AM
Hailers
Oct 12, 2020 10:29 AM
smartobject
Jul 6, 2016 05:28 PM
Jagman1984
Jun 22, 2015 11:23 PM
