slight surging at low throttle.
Old Jul 21, 2013 | 08:47 AM
motomental's Avatar
Default slight surging at low throttle.
Most noticeable at 55 or 65 mph. Has new crank senser. Coils, fuel pump . And coolant sender. I tried at night to see if any coils went bad but nothing obvious. Any thoughs would be great. Car has 109000.mileage.
Old Jul 21, 2013 | 08:57 AM
motorcarman's Avatar
Torque converter lockup engage/disengage????????????
bob gauff
Old Jul 21, 2013 | 09:04 AM
Doug's Avatar
Perhaps a bit torque converter clutch chuggle? It can feel a bit like a surge when it engages and disengages, or even feel like a misfire at times if the engagment/disengagement is a bit harsh.
If the symptom is constant enough to make experimenting meaningful you can take the TCC out of the picture by just tickling the brake pedal very lightly. The TCC should disengage and stay disengaged as long as you're touching the brake pedal. Watch the tachometer for verification. It should jump 100 rpm or so. Of course, don't go on like this for miles as you don't want to overheat the brakes.
Bcrary3
Feb 21, 2023 04:29 AM
scooternva
19
Oct 27, 2015 02:14 PM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
explorer364
Sep 11, 2015 05:44 PM
giandanielxk8
Sep 6, 2015 07:21 PM
