Smoke and smell burned
Old Mar 31, 2021 | 09:17 AM
ARshj's Avatar
Originally Posted by Vee
Your interior looks fantastic....except for the steering wheel! You need to get that wheel replaced, or renewed!!! Then it'll be perfect!
Thnaks agreed
I'm planning to replace it. Coz also I can not adjust the steering wheel for stock motor inside.
I need to budget and also want buy second hand radio original.
Guys can help me for the website can order items for Jaguar 1996 xj6 VDP? Thanks
Old Mar 31, 2021 | 01:36 PM
Parker 2's Avatar
Double click on image for larger view
The lower steering column motor has a gearbox / position sensor assembly that binds up from dried out grease
this assembly pops off with some engagement tabs
You can open it up and clean but be careful of the small parts inside
When you reinstall the position sensor it has to be " clocked "
You can run the motor back and forth with a battery charger but be careful as this is high current and arcing hazard , this is how you would clock it
Make some clip on pigtail wires to bring the connections out to you
https://www.jaguarforums.com/forum/x...fix-faq-53768/
See also
http://www.jagrepair.com/images/TSB/...r%20Seized.pdf
See also
https://parts.jaguarlandroverclassic.../brand/jaguar/
See also
http://www.jagrepair.com/images/TSB/...ng%20Wheel.pdf
See also
http://www.jagrepair.com/images/TSB/...g%20Column.pdf
Scott in PA
Oct 3, 2020 07:55 AM
Jawvdp
Jun 23, 2015 07:12 PM
liquid-chris
Sep 28, 2014 05:31 PM
Glennbar66
Nov 26, 2012 04:28 AM
willow
Aug 15, 2010 02:48 PM
