Sovereign
Old May 10, 2016 | 10:22 AM
Anthea Foulkes's Avatar
Default Sovereign
Hi all, our 4l sovereign, 1996,keeps jumping into sports mode,any clues on how to remedy this, as gets expensive on fuel!!
Old May 10, 2016 | 10:35 AM
Welcome to the forum Anthea,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
Old May 10, 2016 | 01:09 PM
smartobject's Avatar
Anthea - that switch down at the shifter normally has a pretty stiff detent to it, so unless it's broken (as mine is) it should stay put.
Mine, being broken slides easily and will go back and forth.
If you try to remove the leather padded trim around the shifter for a look, be careful about those plastic tabs (on the chrome-plated plastic piece).
Old May 11, 2016 | 04:16 AM
rads's Avatar
My car has a rocker switch for sport/normal. There are two wires on the switch, one is ground and one goes to the transmission control module. When sport is selected the switch is closed and a ground from one wire is applied to the other wire. Maybe your switch is faulty, maybe a wire is chafed through and is grounding? You could disconnect the switch and cover the ends of the wires and see if it stays in normal mode. If it no longer goes into sport then the switch is faulty.
holybananas
May 9, 2016 12:49 AM
jag302
Jun 15, 2013 11:53 PM
x300man
Dec 9, 2012 07:57 AM
RpM
Jun 22, 2008 04:22 AM
