Squeak Sound, HELP!!
Old Sep 21, 2016 | 09:32 AM
Jorge Dias's Avatar
Post Squeak Sound, HELP!!
I own a Jaguar XJ6 1995 and it always has a LOUD squeaky sound, Ive replaced both belts and the only time it stops squeaking is when I put on belt conditioner but then in around 10-15 mins it starts squeaking again LOUDY. Any Fixes?
Old Sep 21, 2016 | 01:49 PM
aholbro1's Avatar
check your crank damper for delamination; a/c idler pulley may be shot.
Old Sep 21, 2016 | 02:10 PM
Jorge Dias's Avatar
The whole A/C Compressor part is brand new, just replaced it
Old Sep 21, 2016 | 03:13 PM
John Dobbins's Avatar
The compressor may be new but the idler pulley located between it and the crank pulley could still be at fault. I don't remember how many idler pulleys there are on a NA car, but probably at least 2.
Old Nov 4, 2016 | 09:21 PM
fmfz12007's Avatar
It's your harmonic balancer more than likely. Make a mark across the pulley with chalk, start the car with all body parts clear of the engine. Shut the car off and check the line . If it's no longer connected as you made it the balancer needs to be rebuilt.
andybsmith
Sep 9, 2016 10:02 PM
reedjs
Sep 4, 2016 10:13 AM
S-TYPE06
Sep 3, 2016 08:10 AM
Jaguar Forums Editor
Aug 29, 2016 05:16 PM
ppolicar
US Lower Atlantic
Aug 26, 2016 09:42 AM
