Stalls and Transmission Light Came On
Old Dec 28, 2011 | 10:13 PM
NupeRangeRover's Avatar
Default Stalls and Transmission Light Came On
Hello Jaguar Nation,
In October I was admitted into the hospital and had open heart surgery; I was there for 34 days. I am recovering now! Before my hospital stay I was having a problem with my '95 Vanden Plas. When I would approach a stop it would STALL and the TRANSMISSION light would come on. I was able to get it started again to drive it home. It has been sitting in my garage every since. I purchased another battery and will put it in tomorrow. I am almost sure that I will still have this same STALL problem as before. Jaguar Nation, I am reaching out to you once again for your HELP! What possibly could this be? Thanks
Old Dec 29, 2011 | 07:48 AM
sparkenzap's Avatar
Just a little better than a guess, but the crank position sensor can be intermittent and if it glitches while the car is moving, it can result in a mismatch of engine and transmission speed sensors, ergo the tranny fault.
Old Dec 29, 2011 | 08:05 AM
Brutal's Avatar
crank sensor, dirty throttle body(especially the idle air control valve passage, remove throttle to clean this, dont leave it on) and or throttle postion sensor(TPS)
those are the top 3 that come to mind
Old Jan 2, 2012 | 12:11 AM
Thanks Brutal, so what should I do? Replace the crank sensor and throttle position sensor and clean the throttle body? What I have gathered reading up on a few post; dirty air control valve or even a dirty idle senor...... Does that make sense and can those items be cleaned without being replaced?
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
