Stock stereo aux-in
Old Oct 18, 2012 | 11:25 AM
Ziggy's Avatar
Default Stock stereo aux-in
I've never had a car this long without swapping the stereo for an aftermarket headunit. I've got loads of them! But in this case, perhaps I'm just getting old, but I kinda like the stock look. I do 'need' somewhere to plug an MP3 player in though, so I'm contemplating adding an aux-in socket via a DPDT switch to the audio lines on the CD changer interface.
Have any of you done this before, or is it worth me taking photos etc?
& yes, I will be fixing the various faults I've already posted about, before spending any time on this!
Old Oct 19, 2012 | 03:25 PM
theJPster's Avatar
I was under the impression the 'line-in' portion of the CD changer interface won't work unless there is an Alpine CD changer fitted. Later head units also require the changer to report the correct (Jaguar) model number, to prevent aftermarket non-Jaguar units being fitted.
I'm in the process of building a box which 'fakes' a CD changer to make the head unit happy. If you know of another way to do it, I'm all ears.
Edit: On second reading, it occurs to me you might already have a CD changer. In which case, I don't see why it wouldn't work! I don't (actually I do, but I want to sell it...)
Old Oct 21, 2012 | 03:58 PM
bliving7's Avatar
I have put aux. in jacks on both my 1995 and 1996 XJs via a simple and cheap FM modulator. It hijacks the antenna input when switched on. I placed the switch in the ash trey. The brand I used (iSimple) came with a nice professional looking black jack labeled AUX IN that I put in a 3/8" hole I drilled through the radio face on the right side. Does not look out of place. The fidelity is as good as a CD. Also tried the little FM transmitters but the fidelity was poor.
bliving7
Old Oct 22, 2012 | 04:40 AM
sbc's Avatar
sbc
Keeping the stock radio is really the only way to go for me, so the iSimple solution seems rather nice. But what I really would like, is to be able to play via bluetooth because of no cables and/or holes to be drilled. I have found the iSimple ISFM21 Tranzit BLU which seems to fit the purpose and it plugs right into the antenna cable too, so the signal will never go on the air, which is a quality killer. Perhaps this could be a solution for the thread starter as well?
Anyone got any experience with this gizmo, or something similar?
Old Oct 29, 2012 | 05:01 AM
Ziggy's Avatar
Thanks for the input all... I do indeed have a CD changer fitted that I'll be keeping - so the simple wiring mod I proposed should be fine without any aftermarket gubbins
I'll take photos anyway - someone might be interested one day!
Old Apr 21, 2022 | 12:38 AM
Kabooom2199's Avatar
Default Aux in
Any chance you took pics and show it was put together. Want to copy this idea....
Old Apr 21, 2022 | 06:40 AM
Vee's Avatar
Vee
Amazon Amazon
Amazon Amazon
The bluetooth cassette adapters may be a simpler fix?
Old Apr 21, 2022 | 04:36 PM
Cafcpete's Avatar
This option is also worth a go for BT integration
https://www.discountcarstereo.com/a2...ategory_id=431
Old Apr 21, 2022 | 05:29 PM
labcoatguy's Avatar
The cassette adapters I've used tend to get noisy with the sound of the rotating mechanism, though that may be because I buy the cheap ones. An inexpensive wired FM modulator plus a Bluetooth aux in has served me well, and Discountcarstereo is also a good source for aux input kits as Cafcpete points out.
Old Apr 21, 2022 | 06:30 PM
Vee's Avatar
Vee
I've never had great reception with the FM ones. Even when the reception came in clear...it didn't for long.
Old Apr 21, 2022 | 09:25 PM
labcoatguy's Avatar
The ones that plug straight into the antenna port on the back of the stock radio are much better.
John Herbert
Jul 16, 2024 04:31 PM
cemanis
Oct 8, 2014 08:33 PM
jaginblack
Aug 13, 2012 08:41 AM
lyonsfin
XJ40 ( XJ81 )
Jan 8, 2011 11:43 AM
XJ40ish
XJ40 ( XJ81 )
Jun 9, 2007 08:25 PM
