Stuck in Park
Old Mar 15, 2017 | 04:05 PM
KATHY PHILLIPS's Avatar
Default Stuck in Park
Hey, My 1995 Jaguar XJ6 is stuck in park. Replaced starter and runs now but wont shift. I have red up some on it. Did take star out and did engage to drive, but still not shifting. No brake lights, no click noise of brake being depressed. Have not checked fuses. Not sure which to check and where. Any info or remedies. Thanks much
Old Mar 15, 2017 | 06:07 PM
Welcome to the forum Kathy,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Mar 15, 2017 | 07:57 PM
JBzXJ40's Avatar
If you're not hearing a click noise, that's the solenoid that locks the shifter in place till you press the brake pedal. You'll need to take the shifter trim ( wooden ski slope ) out of the way and the center console as well. It should a 2 way white connector. Would help to check fuses as well.
Old Mar 15, 2017 | 10:06 PM
Doug's Avatar
Originally Posted by KATHY PHILLIPS
No brake lights,
Faulty brake light switch is likely.
The click come from the shift lock solenoid. The shift lock solenoid is operated by the brake light switch.
'Sometimes' jabbing the brake pedal very hard gives temporary relief.
Old Mar 16, 2017 | 01:30 PM
Thanks much. The parts house suggested it might b the neutral switch. Now if the solenoid is bad would that stop the brake light from coming on also? by the way all the J lights are working when key is on, if that makes a difference. Thanks again
Old Mar 16, 2017 | 02:00 PM
Did jab brakes super hard and it worked brake lights now clicking noise and J works. Hope this isn't just temporary.
Old Mar 16, 2017 | 02:48 PM
dagny747's Avatar
Check this thread out......because jamming the brake pedal hard is temporary and its really not hard to fix except for having to be upside down for awhile ;-)
https://www.jaguarforums.com/forum/x...hanism-172126/
Old Mar 16, 2017 | 04:38 PM
JBzXJ40's Avatar
If the brake lights aren't working, most likely its the brake switch.
Old Mar 16, 2017 | 05:00 PM
Thanks all for the tips. Going to look into the brake light switch.
