Subs?
Old Jul 20, 2010 | 07:09 PM
Chavid92's Avatar
Originally Posted by Doug
Sorry, no. I didn't even think to look.
no problem. your jag did come with premium sound right (you didnt install the sub later)? Next time you get the chance could you pull back the corner of the carpet and see if you have those wires or not? thanks
Old Jul 24, 2010 | 04:33 PM
Chavid92's Avatar
Originally Posted by Oubadah
I'm still determined to make use of the oval subwoofer mount in the parcel shelf and I managed to find one 6x9" subwoofer by Lanzar (heard only bad things about this brand):
http://www.lanzar.com/itempage.asp?model=VB69
I'm almost tempted, but do you think there would be enough clearence for that fat magnet over the tank?
Lanzar don't deem it necessary to provide specs on the depth of it...
crutchfield has a mounting bracket that makes it so you could put a 6.5 inch sub in the shelf (http://www.crutchfield.com/p_142SA69...-Brackets.html) with like this sub (http://www.crutchfield.com/p_2060CVT...-10CVT654.html). just a thought.
Old Oct 13, 2010 | 10:13 PM
Oubadah's Avatar
Only just noticed this post. Thanks for the links!
Can anyone that the Jag parcel shelf mount uses standard 6x9" dimensions and screw positions?
EDIT: That Kicker sub is supposed to be 7.3cm deep, and I measure 6.5cm of space above the tank (and that's only on the side that doesn't have the metal strap around it!). Sub would have to be a little proud... But I'm keen to give it a try when I next have some spare cash, and I actually managed to find the sub in NZ!
Now there was someone who started a thread saying they were going to install a 6.5" sub in the parcel shelf, and promising pictures... Was that the same sub, or is there an alternative shallow mount 6.5"?
EDIT 2: Here is another one: Earthquake "SWS-6.5". Looks like mounting depth is under 5cm! Availability is a little poor.
Old Oct 14, 2010 | 10:16 AM
Drew's Avatar
I have 2 shallow mount kickers in my 04 XJR. They are cheap and work well. They might work for this application.
Old Oct 14, 2010 | 06:38 PM
Chavid92's Avatar
I ended up getting a shallow mount 8in pioneer TS-SW841D. i then widened the hole cut for the 6by9 sub using a dremel tool and cut some wood dalls to level it for mounting. It adds alot of bass and makes use of the stock hole where it does not take up trunk space and cannot be seen unless the rear self is out or you pull back the carpet. i love my new system! Will post pic once i put them on my computer from my phone.
Old Oct 14, 2010 | 06:46 PM
Chavid92's Avatar
My sub...
Old Oct 14, 2010 | 06:50 PM
Oubadah's Avatar
Thanks for the pics. How hard is it to remove the plastic cover that is over the parcel shelf?
Old Oct 14, 2010 | 06:55 PM
  #28
Chavid92's Avatar
You have to remove the rear seats... But dont let that turn you away. to remove the rear seats and shelf it took me about 30 min or less this being my first time ever doing it.
Old Oct 15, 2010 | 08:06 PM
Oubadah's Avatar
Does anyone have a stock Jaguar sub, or exact measurements of the opening? I need to verify that it is indeed 6x9.
Old Oct 16, 2010 | 12:38 AM
  #30
Chavid92's Avatar
I have a stock jaguar sub but am not sure on the size of the opening.
Old Oct 16, 2010 | 01:31 AM
  #31
Oubadah's Avatar
I have a stock jaguar sub.
Would be great if you could give me the width and height (at widest points), approx depth, and distance between screw holes.
Old Oct 17, 2010 | 10:47 PM
  #32
jhxj6's Avatar
About how much clearance is there between the shelf and the tank? I was looking today and was wondering if my 12 inch kickers could possibly fit. it's 20.7cm deep so this is probably way way out of the question
________
Alaska Medical Marijuana
Old Oct 18, 2010 | 01:58 AM
  #33
Oubadah's Avatar
Roughly 6.5cm as mentioned on the last page. But thats not including the metal strap thing that goes over the tank, and that is under a third of the stock opening.
Old Oct 26, 2010 | 08:53 PM
  #34
Chavid92's Avatar
Hey sorry it took so long to respond. i have been in tokyo and just got back. Next time i get the chance i will take the measurements and get them to you.
Ok so its widest points are 9x6.5inches
Its depth is 3.5inches
and the screws sit at 4.5x6.5inches apart
Old Mar 25, 2011 | 07:33 AM
  #35
SRL1990's Avatar
Are there wires already hanging out for the Rear sub? or you gotta get your own? I have no premium sound I believe. 1996 VDP
Old Mar 25, 2011 | 04:41 PM
  #36
Chavid92's Avatar
Nope gotta run new wires.
mbergen
Oct 23, 2019 10:26 PM
damienedwards
Nov 22, 2015 10:51 AM
pino
Sep 26, 2015 08:05 PM
buickfunnycar.com
Sep 25, 2015 10:02 AM
R-Sport
Sep 18, 2015 01:44 PM
