Telescope motor drive
Old Jul 24, 2014 | 03:19 PM
sogood's Avatar
Default Telescope motor drive
Some time ago, maybe 12 months back, I replaced the little shaft in the motor that provides the telescope action to the steering wheel. I used the shaft from my donor car, so maybe it wasn't the best to start with. Also, I didn't change/adjust anything else in the process, but maybe the telescope action had to be set or reset, as I remember reading something to this effect, after I had done my repair.
Now the replacement has gone awol also, with the steering wheel set back very close to the dashboard, along with the wiper and indicator switch! It won't pull forward manually, so I was wondering, is the specific "wire bound" shaft really needed, or would a similar sized square shaft do the same job, provided the set up was positioned properly during assembly/replacement.
Thanks in advance.
Old Jul 25, 2014 | 02:35 PM
xjrguy's Avatar
Thanks in advance.
I can tell you that the flexible drive 'cable' is what you really want. At a friends request several years ago, I had a straight piece of bar stock machined to try. If it was machined to the exact square dimensions of the cable, it would not work. There is just a small bit of an angle difference between the motor and the column gear. We machined the bar square a bit smaller than the cable, and got it to work, but it was noisy. He used it about a year and it chewed up the column gear.
Coventry West now makes a replacement cable so it can be repaired without a reach motor.
Good luck!
Old Jul 25, 2014 | 08:56 PM
motorcarman's Avatar
I have written about this before (as have others and I think the horse is dead and does not care if is beaten).
If you simply replace the cable and DO NOT reset the position sensor 'end-points' then it will stall the motor and FAIL AGAIN if AUTO is used!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PLEASE............... If you replace the drive cable and have NO IDEA how to reset the stopping points, then SWITCH THE COLUMN SWITCH TO OFF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Using the MANUAL column function gives the motor/cable half-a-chance of survival as YOU can stop the motor when it reaches an END. The AUTO function will drive the motor until it reaches the position sensor limit. If the 'electrical' limit is not reached, the motor continues to drive until the cable fails, the motor burns out OR the plastic column drive BREAKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Think about it. If you want to stop at an intersection, but there is a car in front of you, your car needs to stop 20 or 30 feet BEFORE the intersection or you will try to occupy the same space as the other car. You can try the excuse "Well I stopped at the intersection but some idiot was in my way!!"
The motor/sensor wants to travel until it is told to stop.
I usually set the limit with the motor/sensor plugged in but NOT installed. You can run the motor all the way IN and move the column ALMOST all the way in so the motor STOPS before the column STOPS!!!!!!!!!! THEN install the motor.
You need to read through the vast amount of info posted on this forum over the years. Do a search of 'column reach fault' or something like that.
The X300, X308 and X100 all use the same type of column and drive assy.
bob gauff
Old Jul 26, 2014 | 08:20 AM
Jaypimca's Avatar
Hi, I am looking for a headlight powerwash jet left side for my Jaguar XJ6 1997. Could someone tell me where I can get one. So far in Canada they are back order and, if ordered, out of price. New, used or from a scrap.
Thanks for your help.
Old Jul 26, 2014 | 10:45 AM
sogood's Avatar
Hi Bob and thanks a load for that detailed and possibly somewhat exasperated explanation. It's as much as I expected and I promise, when I replace the drive, to set it all up properly. And if I have any doubts, I will certainly leave the "Auto" setting switched off.
It's just convenient to have the wheel retract as I'm a bit long legged and I appreciate the extra room when getting out of the car.
Thanks again.
toronadomike
Jan 22, 2026 10:13 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
XJsc-guy
Sep 2, 2015 11:43 AM
