Throttle position sensor X300
Old Jan 28, 2015 | 07:37 PM
John Herbert's Avatar
Default Throttle position sensor X300
Have recently completed some research on alternative TPS & have ascertained that a very likely option is perhaps a Standard TH198 & equivalents which are Wells TPS246, Motorcraft CX1528, Tomco 14042, Walker 200-164. Its a very common TPS fitted to many USA Ford models.
It appears the drive pegs are in the same position as the Jag part which is JLM12074 or Standard TH417. I assume both it & the Jag part turns clockwise & that voltage range is very similar (0.6v idle to 4.9v full throttle)
Perhaps other members may have done further research & add to this quest for an alternative replacement to this costly Jag part.
Old Feb 1, 2015 | 12:01 PM
al_roethlisberger's Avatar
This would be great news, especially if the TPS is much cheaper.
I have a TB I'd like to get a TPS for as it didn't come with one.
Has anyone tested?
Old Feb 4, 2015 | 11:25 AM
EZDriver's Avatar
Couple years ago I researched the Ford Scorpion as an option for the TPS(see thread below). I found the Ford rotated in the wrong direction. Hope this helps. Please keep us informed as to new results.
https://www.jaguarforums.com/forum/x...-sensor-92121/
Old May 6, 2021 | 04:52 PM
Matto1965's Avatar
Hi did you ever get any further with the identification of a suitable aftermarket TPS ?
BlackJack
Oct 10, 2022 05:22 PM
Matto1965
May 7, 2021 05:20 PM
Brewtech
Oct 2, 2019 05:03 PM
EZDriver
Mar 22, 2013 07:50 AM
EZDriver
Dec 31, 2012 12:29 PM
