traction control failure
Old Oct 25, 2014 | 05:14 PM
dgolmd's Avatar
Default traction control failure
is it safe to drive what do I do?
Old Oct 25, 2014 | 07:38 PM
RJ237's Avatar
Yes it's safe to drive. Are there any other lights or messages, like ASC or ABS related?
It could be a wheel speed sensor , connecting cable or abs module problem. It means your wheels will not be prevented from breaking loose by the management system, you'll have to do it yourself until it's fixed. Even a weak battery could cause an error like that to be displayed. Use the search function to find threads dealing with the subject.
When you have time, please visit the new member area and introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Oct 26, 2014 | 03:06 PM
FrozenApple's Avatar
You should pull the code first before doing anything!
Old Oct 26, 2014 | 03:52 PM
RJ237's Avatar
Generic code readers will not find abs related codes, so a trip to the dealer or independent repair shop would be required. Many of us would rather attempt to isolate the problem and repair it before resorting to that expense.
bdboyle
Sep 16, 2019 05:58 PM
ryan_border
Dec 23, 2015 04:27 PM
Steve10
Sep 20, 2015 12:27 PM
mrobinson
Sep 18, 2015 07:20 AM
Johnken
Sep 15, 2015 05:46 PM
