plums
close
- Join DateFeb 2011
- Locationon-the-edge
Liked:2,201 Times in 1,633 Posts
Apparently it is a manual XJR6:
see the subframe and upper bush move around, i think i see the vee mount lift as well.
Doug
close
- Join DateMar 2008
- LocationPacific Northwest USA
Liked:11,718 Times in 7,584 Posts
Quote:
Yes, but what amount of movement is normal/benign?
plums
close
- Join DateFeb 2011
your guess == my guess
of course it is possible to do videos of both sides
and if one is worse than the other, then its food
for thought.
for thought.
sparkenzap
close
- Join DateNov 2007
- Locationatlanta ga
Liked:1,068 Times in 870 Posts
AT least the Go-Pro didn't fall off!
plums
close
- Join DateFeb 2011
Quote:
Let me have another stab at this Originally Posted by Doug
Yes, but what amount of movement is normal/benign?Cheers
If the bush moves more than the amount needed to change a
the wheel alignment by 'x' degrees where 'x' would be unacceptable
error in the static alignment ... there is potentially a problem.
Of course, vee mounts lifting would be a Bad Thing(tm).
plums
close
- Join DateFeb 2011
Quote:
I found the video fascinating. Much more interesting than watching sayOriginally Posted by sparkenzap
Jeremy Clarkson smoke tires around a track.
Especially since I discovered what seems to be a worn upper right balljoint
last night while preparing for a pad slap.
The tire can be rocked at the top by 1-2mm but not at the bottom
or sides. A finger spanning the hub to upper control arm joint area
can detect movement at the joint. Through a work glove.
Hmmm ....
I would occasionally get tramlining on certain road conditions but it stopped when I changed all four tyres, incidentally if any ones interested I had four "Landsail" tyres fitted they are a midpriced Chinese tyre and despite my initial concerns regarding quality they have been just fine and after seven months of use I've no complaints.
RJ237
close
- Join DateDec 2010
- LocationDouglasville Ga.
Liked:2,924 Times in 2,317 Posts
Tramlining is when the car appears to be following a groove in the road and not responding to small steering corrections. If you have ever driven on a street with streetcar (tram) tracks you will notice the unpleasant sensation immediately.
I had that problem with my Z3 when I bought it, but new tires fixed it Worn suspension and steering bushes can often result in the same sensation.
I would remove the cable tie from the hoses to the brakes - it is preventing free movement between the two ends, effectively creating two shorter lengths,and so causing more stress/bending on the hoses, which will fail sooner.
