tramlining and an interesting way of evaluating bushes
Old Oct 18, 2015 | 04:28 PM
plums's Avatar
Default tramlining and an interesting way of evaluating bushes
Apparently it is a manual XJR6:
see the subframe and upper bush move around, i think i see the vee mount lift as well.
Old Oct 18, 2015 | 05:37 PM
Doug's Avatar
Yes, but what amount of movement is normal/benign?
Old Oct 18, 2015 | 05:39 PM
plums's Avatar
your guess == my guess
of course it is possible to do videos of both sides
and if one is worse than the other, then its food
for thought.
Old Oct 18, 2015 | 08:08 PM
sparkenzap's Avatar
AT least the Go-Pro didn't fall off!
Old Oct 18, 2015 | 09:12 PM
plums's Avatar
Let me have another stab at this
If the bush moves more than the amount needed to change a
the wheel alignment by 'x' degrees where 'x' would be unacceptable
error in the static alignment ... there is potentially a problem.
Of course, vee mounts lifting would be a Bad Thing(tm).
Old Oct 18, 2015 | 09:14 PM
plums's Avatar
I found the video fascinating. Much more interesting than watching say
Jeremy Clarkson smoke tires around a track.
Especially since I discovered what seems to be a worn upper right balljoint
last night while preparing for a pad slap.
The tire can be rocked at the top by 1-2mm but not at the bottom
or sides. A finger spanning the hub to upper control arm joint area
can detect movement at the joint. Through a work glove.
Hmmm ....
Old Oct 19, 2015 | 04:55 AM
Mr happy's Avatar
Default Re tramlining.
I would occasionally get tramlining on certain road conditions but it stopped when I changed all four tyres, incidentally if any ones interested I had four "Landsail" tyres fitted they are a midpriced Chinese tyre and despite my initial concerns regarding quality they have been just fine and after seven months of use I've no complaints.
Old Oct 20, 2015 | 08:57 AM
EZDriver's Avatar
I hate to sound dumb. But what does the term tramlining mean????
Old Oct 20, 2015 | 10:04 AM
RJ237's Avatar
Tramlining is when the car appears to be following a groove in the road and not responding to small steering corrections. If you have ever driven on a street with streetcar (tram) tracks you will notice the unpleasant sensation immediately.
I had that problem with my Z3 when I bought it, but new tires fixed it Worn suspension and steering bushes can often result in the same sensation.
Old Oct 23, 2015 | 01:27 PM
AL NZ's Avatar
I would remove the cable tie from the hoses to the brakes - it is preventing free movement between the two ends, effectively creating two shorter lengths,and so causing more stress/bending on the hoses, which will fail sooner.
brgjag
Dec 11, 2015 02:26 PM
scarbro2011
Oct 25, 2015 08:09 PM
Stoney85
Oct 19, 2015 04:14 AM
teddy1dog
Oct 16, 2015 06:43 PM
Larry-Cleveland
Sep 28, 2015 10:04 AM
