Transmission leak
Old Dec 27, 2018 | 09:29 AM
cdma's Avatar
The only reason I said M20 is that is the tap that I used to smoot in the threads on the old bolt. I will try the 19 and also look at the 10mm 1.5 to see if that also fits.. Thanks. May be a little cheaper than
Old Jan 16, 2019 | 08:43 PM
Lady Penelope's Avatar
Got your fulcrum bolts in my hand , see PM
Old Jan 17, 2019 | 12:57 PM
annamiata's Avatar
Before spend big dollars to fix leak from power steering rack and pinion. Go get some Lucas power steering stop leak. I do not believe in snake oil but this additive worked on my sold 90K miles 1997 XJ6. Its rejuvenated seals and stopped leak. If it does not work then fix. It's cost $10.00
Old Jan 18, 2019 | 09:32 AM
Don B's Avatar
The Lucas Transmission Fix is another great product that has been effective for me a few times to smooth gearshifts and slow or stop leaks at transmission seals.
Cheers,
Don
Z07Brandon
Jun 22, 2017 11:48 PM
HypnoGuru
Oct 28, 2016 09:08 AM
chtp66
May 26, 2014 06:45 AM
veffremov
Jul 1, 2008 12:41 PM
Dream Car62
Apr 22, 2008 12:13 PM
