Transmission Mount cracked advice needed please
Subscribe
May 27, 2017 | 01:05 AM
Asking for repair options . My Lady P. has 2 cracks I spotted in removing the exhaust line . Can it be done on- car . Or does the casting have to come out ? One of the cracks is at the yoke or juncture of 2 to 3 cross member . I at this time have the Y - pipe section cut out for repairs so will possibly have to cut out another 12 inches .
Thanks , Parker
Reply 0
May 27, 2017 | 06:21 PM
I had a customer that complained of noisy/vibrating engine and found the aluminum bracket completely broken and laying on top of the exhaust pipe.
I would get a good used bracket (or remove and attempt to weld it).
They can't cost much from a salvage yard.
bob
Reply 0
May 27, 2017 | 08:15 PM
Thanks Motorcarman , Looks like may biggest obstacle is to remove the aft intermediate exhaust silencer section because I can't get a driveshaft shoring cradle with it in the way . Exhaust clamp seizures and cut and splice limitations . So I may have to hope for the best to get past Missouri inspection and have it welded in place on car at a later date ( if that is possible ). Probable my best option in my driveway . Luckily it is not completely broke ( yet ) .
Thanks , Parker
Reply 0
May 28, 2017 | 08:39 AM
You can use a pipe chain cutter and a dual clamp exhaust sleeve.
Reply 0
May 28, 2017 | 01:53 PM
Thanks , been looking for a cuplier like that for the past week . The standard has the round threaded U bar that takes to much space . Used a cut off wheel to get the y pipe off earlier and the pipe chain cutter you suggested may be a solution aft of the intermediate silencer section .
Thanks , Parker
Reply 0
May 28, 2017 | 03:38 PM
VW/Audi uses these coupler sleeves but they are metric so I don't know the fit for the X300 exhaust.
I'm sure places like JEGS or SUMMIT RACING etc. carry something like this.
bob
Reply 0
May 28, 2017 | 06:46 PM
Lady P pipes are 60 mm or 0.365 inch shy of 2 and 3/8 OD with a micrometer with some exceptions .
Thanks , Parker
Reply 0
May 26, 2021 | 01:44 AM
Quote: Asking for repair options . My Lady P. has 2 cracks I spotted in removing the exhaust line . Can it be done on- car . Or does the casting have to come out ? One of the cracks is at the yoke or juncture of 2 to 3 cross member . I at this time have the Y - pipe section cut out for repairs so will possibly have to cut out another 12 inches .
Thanks , Parker
I have always wondered: what is the purpose of that round rubber part labelled as no.8 in the diagram?
Reply 0
May 26, 2021 | 09:41 AM
That got me to looking at other X300's to see if it ties into something and it does not
Can only speculate how it got there and if it was for a different engine option that never materialized like a diesel / transmission
Reply 0
May 26, 2021 | 09:18 PM
Vibration damper!!!!!!!!!!!!!
Reply 1
May 26, 2021 | 09:32 PM
Quote: Vibration damper!!!!!!!!!!!!!
Ahhhh! Did not think it would be for that. Curiosity satisfied. Thank you!
Reply 0
Subscribe
Currently Active Users (1)
