Transmission / starting
Old Oct 8, 2020 | 12:44 PM
haroldpeacocksr's Avatar
Exclamation Transmission / starting
1996 XJR. Car wouldn't start; (no power of any kind) If I put it into park "hard" then sometimes it worked. I was advised to replace the Transmission Decoder. a small 3" plastic unit with a slider in it mounted under the shift lever panel on the side. This resolved the problem, temporally, now I have a new problem, the mechanic that did the work didn't do the job correctly, now the shifting mechanism is all out of whack. I called the Jag dealer in Seattle and they don't work on this older car (96) and neither do the two garages they recommended. . .So! Does anyone know a mechanic/garage within a 100 /200miles of Tacoma that I could take my XJR too?. . ."HELP"!
Old Oct 8, 2020 | 01:03 PM
motorcarman's Avatar
You have a 4L80E so just call a few transmission shops to see if they are familiar with it.
Old Oct 9, 2020 | 06:18 AM
There arn't any that I can find, that's why am asking if anyone knows one
Old Oct 9, 2020 | 02:54 PM
It's a GM transmission. There must be independent tranny shops in your area?
From wikipedia........
"4L80-Es were optioned only in Chevrolet/GMC pickups, Suburban 2500s, vans, and commercial vehicles, and the Hummer H1"
Someone has to work on the older vehicles in your area?
I used to pull the THM 3L80 (turbo 400) from Jaguar V12 and XJ-S to get repaired at a local AAMCO shop in the 1980s.
These are NOT an 'exotic' gearboxes.
haroldpeacocksr
Oct 8, 2020 02:43 PM
jagskiguy
Oct 24, 2018 01:25 PM
Shane8362
Sep 6, 2012 06:56 PM
Shane8362
Aug 27, 2012 06:49 AM
