Vacuum hose question
Old Mar 23, 2024 | 03:33 PM
MichiganJag's Avatar
Default Vacuum hose question
I replaced my fuel lines with no issues.
under the hood firewall we have the factory steel lines on drivers side running together. Fuel, brake, and assuming vapor lines.
2 turn from steel to rubber. One is attached to intake on top towards firwall, but the other was just laying there.
Ideas as to where I connect it?
Where they come from
Old Mar 23, 2024 | 04:22 PM
RonXJR's Avatar
My XJR lines from the firewall are as shown below. I don't know if the XJ6 lines are the same as my 95 XJR and the rubber line for mine is connected to the throttle body as shown. Hope this helps!
Throttle body
Fire wall
Old Mar 23, 2024 | 06:12 PM
Thanks Ron, appreciate it. But since I'm not familiar with that model, I can only see 2 rubber lines coming up similar to mine.
you said one goes to intake but what is your second one go to? Same as you I have 2 and one is connected to intake other just sitting. I assume they're both going to vape in back. My worry is that where ever the the unconnected one goes there's a open port which explains the minor idle shake I got.
Little perspective. Tip picture. You see wiper motor back end and red dipstick. In that hole is all lines coming up. And you can see one rubber line coming up looping over connected to intake. Thats one.
Pointed to one rubber hose from steel line bundle, connecting to intake
Second hose held that needs a home. In background you can see its twin from steel bundle that is plugged into the intake
Old Mar 28, 2024 | 08:33 PM
Parker 7's Avatar
See page 60
Notice the 2 versions and does not include supercharger or brake boost
jagrepair.com/images/Training Guides/801S - 2000.pdf
Old Mar 29, 2024 | 01:47 PM
Thank you Parker. Safe to believe it's the vent hose that needs no connection since the second hose from the back is already connected to the intake.
MUCH appreciated!
Old Mar 29, 2024 | 03:22 PM
Parker 7's Avatar
On the 4 corners of the roof there are drain lines as well as the A / C plenum
MudDog
Sep 1, 2022 07:59 AM
Mrs.grisby
May 16, 2022 08:18 PM
pianoman90
Apr 21, 2022 10:08 AM
OUScooby
Aug 4, 2019 02:37 PM
Lancer-AM
May 30, 2012 11:18 AM
