Valve seat contact width
Old Feb 2, 2022 | 02:57 AM
Peter Pennström's Avatar
Default Valve seat contact width
Hi everyone!
I'm currently working on a cylinder head of an AJ16 XJR. My exhaust valves are quite pitted and kind of burned so I'm having an experienced friend helping me re-grinding them and the valve seats. I have the AJ16 manual pdf and I've been searching for all measurements and angles needed, but I can't find anything about the contact width of the valve seat.
Does anyone know this?
And I don't see any specs unique for the supercharged version, aren't the inlet valves bigger on those engines? And is the valve lift the same on N/A and SC?
In very grateful for any kind of help here!
Old Feb 2, 2022 | 10:21 AM
Parker 7's Avatar
Page 36 of the AJ16 Engine Range Service Manual ?
I don't have the SC engine but have picked up hints there are some that have a beyond factory spec and recommendation
Old Feb 2, 2022 | 02:39 PM
Yes I've seen that, but it only shows a picture of how high the valve should be seated, in my mind a kind of strange thing to emphasize... It doesn't really help I'm afraid. Thanks anyway!
Old Feb 2, 2022 | 11:21 PM
Jagboi64's Avatar
I believe the valves are the same between the supercharged and normally aspirated. Earlier engines have the same part number for both exhaust valves.
Cams have different part numbers, so I'm assuming the profiles are different.
Old Feb 2, 2022 | 11:35 PM
Parker 7's Avatar
The number on the cam is a blank part # before machining down
So it might be hard to nail down which cam is installed unless TSB 03.1 - 05 has been performed and notated properly
Something I picked up from reading without knowing for fact
http://jagrepair.com/images/TSB/X300...%20Changes.pdf
Old Feb 4, 2022 | 03:12 AM
So I'm assuming that even if the cams have different profiles, the clearence is the same because the manual only show one spec.
Or is there a specific manual for the supercharged version? I haven't found one at least!
I really hope that someone who's done a valve Job on these can share some experience here. Otherwise I have to look at some other similar engine for the specs...
Old Feb 4, 2022 | 09:31 AM
Parker 7's Avatar
There should be someone to come along
But the weather here in the states is cold and snowy right now
I have in mind someone in New Zealand off the top of my head that I think did a valve job on the SC version
Old Feb 5, 2022 | 06:58 PM
Larry Louton's Avatar
The cylinder heads are the same between except for the camshafts, The clearances between the lobes and valves are the same.
Larry Louton
jagski2
Apr 11, 2023 09:01 PM
Reverend Sam
Sep 6, 2021 05:28 PM
sidescrollin
May 9, 2018 07:47 AM
superchargedtr6
Dec 1, 2014 09:20 PM
jagstein
Feb 22, 2010 02:43 PM
