Dropped valve seat
Dropped valve seat
I have a 2000 XJ8 with 130k miles. Motor overheated and it dropped at least 1 valve seat as per my analysis. Question is. Should all seats be replace or just the bad one, or maybe 2. Since I have to pull 1 head, I will just pull both, which leads me to the next question. Back in the day, valve jobs were easy and straight forward. I m replacing the chains and guides as well. From the opinion of experienced Jaguar enthusiasts, should I pull both heads or just fix the 1 seat and have a beer. Any response is well appreciated. Ordered the tools and parts, so I have time to ponder
I would suggest locating replacement cylinder heads - far easier on the wallet and also carry out a timing chain tensioner job while the engine is down - unless they've been taken care of already.
The main reason for head swap is an over temp event on these usually leads to further valve seat problems, but it's just a case of running the numbers and figuring out which route is cheaper and faster with the least risk.
Dropped valve seat - completed
Thanks for the replies before I dug into it. Pulled heads and replaced all seats. $10 each. Put on new chains and tensioners. A few items that being the first time I've gotten that far into the motor. Buy the correct tools,- cam hold down, crank lock and crank balancer puller. Bought online for $380. I destroyed the crank sensor getting it out, the overheat ruined the cam sensors. Throwing lean codes on both banks, I found a vacuum line off and also replaced the MAF sensor. All is good and happy to be driving the baby again. Total cost with valve job, seats, tools, gaskets etc about $1800. Thanks again
The following 8 users liked this post by jagski2:
96x300 (11-18-2018),
Carnival Kid (11-19-2018),
earny (04-12-2023),
ericjansen (11-19-2018),
jackra_1 (11-19-2018),
and 3 others liked this post.
if you don’t have air a cordless 1/2 high torque some extensions a swivel, deep 24 and some electrical tape so you don’t send your socket flying
X308er (04-15-2023)
roycej
06-07-2022 10:52 PM
