Video of X300 on the production line
Old Sep 25, 2022 | 01:58 PM
Cafcpete's Avatar
Default Video of X300 on the production line
Just seen a FB post linking to this video, and although slow it’s fascinating to watch!
Old Sep 25, 2022 | 09:46 PM
Don B's Avatar
I can never resist watching this!
I am amazed that they install the engine and transmission from above with the hood attached to the body! Why wouldn't they install it from below when they are installing the subframes and driveline?
Old Sep 25, 2022 | 10:27 PM
Parker 7's Avatar
You have to raise the production line ruining a limited production floor space or dig a hole in the floor and it's disruption in terms of safety and ramping down to get the drivetrain there to start the installation
Just guessing
Old Sep 26, 2022 | 12:05 AM
Don B's Avatar
Just guessing
You may be right. But the jig for installing the subframes and driveline seems nearly as tall as the engine. And this was well into Ford's ownership, so you would assume there were discussions about optimal assembly methods, and this was either the best possible method or the best compromise due to other factors such as the ones you mention.
Old Sep 26, 2022 | 12:20 AM
Mkii250's Avatar
And there at 05:32 is an X300 going down the line with a leaper affixed. I thought.....never mind.
Old Sep 26, 2022 | 02:21 AM
944play's Avatar
I had the same thought and commented on the video to that effect. A reply claims that the V12s only were fitted from the top because they would not go through the frame rails from underneath.
Z07Brandon
Sep 15, 2022 11:12 AM
olivermarks
XJ XJ12 ( X305 )
Aug 17, 2019 07:18 AM
MediaBobNY
Apr 19, 2017 04:07 AM
CatoBT
Jun 22, 2011 03:57 PM
