washer pump not working
Old Mar 24, 2013 | 09:57 AM
Gareth Reaper Pollard's Avatar
Default washer pump not working
Good afternoon all,
The washer pump on 97 x300 packed up the other day. Just gotten round to replace the pump with a new part. (wrong part from ebay lol) but i tested the old pump when out of the car and it works.
So this leads me to believe it is a fault somewhere in the electronics on the car. checked the fuse. it's fine. Relay clicks. although the wiper no longer wipes when pressing the washer button. Wipers work fine on all other settings.
Tested the pump connector and there is no power there at all
Old Mar 24, 2013 | 11:45 AM
sogood's Avatar
It sounds like the wiper stalk switch isn't doing its' job. Have you got wipers working in the normal way, by flicking the stalk up or down for full on and intermittent?
Pressing "in" powers the pump and wiper, so maybe check for power out of the switch, beneath the steering column shroud. Test for power out in all settings, just to be sure!
The switch may just need a little cleaning, unless it's gone kaput altogether.
Old Mar 24, 2013 | 12:14 PM
Button on the stalk looks the most likely culprit from what you've described.
Old May 3, 2013 | 06:41 AM
Thanks for the info guys. But after much testing I founf it to be a dodgy Relay. It clicked but no output.
Sprayall
May 30, 2021 08:13 AM
Russ Graber
Feb 23, 2019 11:59 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
