Water temperature gauge issue or not?
Old Apr 12, 2024 | 11:25 AM
  #41
Parker 7's Avatar
I'm not getting good meter readings on the AB version module that rattles
So looking for other module , its buried deep under stuff
Old Apr 12, 2024 | 01:31 PM
  #42
Cafcpete's Avatar
Originally Posted by Advinnie
is there a third fuse or not? If so do you know where it is. I can’t find it and Parker 7 does not think there is one now.
I was just going off this thread from another site
https://forums.jag-lovers.com/t/x300...relay/223037/1
Old Apr 12, 2024 | 02:06 PM
  #43
Parker 7's Avatar
On that Jag - Lovers website
Researching as I think they have the V - 8 and inline 6 models mixed ( V - 8 had the electrical system redesigned and uses a very different engine management fuse box )
The V - 8 uses the engine management computer to give coolant temp commands to the radiator fan relay module
" The fans are supplied via the engine management fuse box,fuse 14
(10 amp)out of 18. This feeds the radiator fans controll module
located behind the left hand side of the bumper.________________"
See page 103 for 2000 year V - 8
X300 00/E COVER (jagrepair.com)
Point 60 E is fuse # 14 different engine management fuse box
Old Apr 12, 2024 | 03:58 PM
  #44
Cafcpete's Avatar
Well spotted Parker.
Old Apr 12, 2024 | 04:10 PM
  #45
Parker 7's Avatar
Old Apr 15, 2024 | 11:50 AM
  #46
Advinnie's Avatar
don’t have a fuse box that looks like that?
Old Apr 20, 2024 | 10:54 AM
  #47
Advinnie's Avatar
Hi all just to wrap up this thread. The cooling fans are now working as they should. It was a bad relay that was causing all the trouble.
the thermostat was changed to a different brand and now the water temperature warms nice and fast and the gauge needle now sits on the normal mark on the gauge. I have hot air with in minutes when the AC is off but I still have an issue that the second I select AC on even when the temperature is set to max the air will at best only come out Luke warn but turn the AC off and the temperature increase to very hot.
inertian
Mar 11, 2022 09:08 AM
97XJR-Flausa
Dec 4, 2015 08:43 AM
YycXJS
May 4, 2014 03:11 PM
BmoreDuke
Oct 29, 2012 01:31 PM
tag1000
May 17, 2009 11:39 AM
