Weird radio behaviour
Old Mar 7, 2016 | 04:55 PM
matade's Avatar
Default Weird radio behaviour
My '97 X300 radio has started to misbehave in the most weird way. When I enter the car and switch on the radio for the first time after turning the ignition key, it doesn't switch on. However, if I press the cassette button beside the radio on/off switch and then press the on/off switch, it switches on and operates as normal, that is until after a while it may decide to stop responding to any of the buttons, including volume control, until I press the cassette button again.
This car is not used very often, about 5 or 6k miles a year, so it is hardly a major issue. But it is annoying and I wonder if anyone has come across this before and if there is a DIY solution.
Many thanks.
Old Mar 7, 2016 | 07:11 PM
al_roethlisberger's Avatar
Very common issue actually.
There are several threads on radio problems & repair options covering this specific topic. I had the same issue and sent it to a repair shop for repair.
The only real option is to find a repair shop that will rebuild the radio and fix all the cold solder joints. In the US this costs about $250
You might find the following threads helpful:
https://www.jaguarforums.com/forum/x...estion-138542/
https://www.jaguarforums.com/forum/x...nt-turn-54075/
Good luck!
mastersid
XE ( X760 )
Dec 22, 2015 04:08 PM
elude
Jun 8, 2015 03:54 PM
Kjamo
Nov 13, 2014 07:01 PM
John Delaware
Dec 4, 2012 07:06 PM
85_305
Dec 2, 2009 06:07 AM
