What is this switch and how to remove it
Old Oct 30, 2022 | 04:35 PM
  #121
sturner's Avatar
Well, Found the problem for the no start, Since I couldn't find a OEM style "Not in Park Switch" I had to jerry rig a different one, And once the center counsole was put back together once in park the shifter wasn't making good contact with the switch lever, So while removing the screw the head twisted off which means I had to pry the switch off which means it broke so now I have to find another one.
Old Oct 30, 2022 | 04:45 PM
  #122
Parker 7's Avatar
The red button on the microswitch has a dimension that it has to be depressed to make , this is also important on the wiper park switch
This dimension is hard to find from vendors and off the top of my head comes in 5 and 10 MM but that's too large of a scale
Old Oct 31, 2022 | 02:10 PM
  #123
sturner's Avatar
Got a new switch ordered, While I'm waiting for it what in the world is this thing?
Old Oct 31, 2022 | 07:16 PM
  #124
Parker 7's Avatar
I tried to get to a salvage yard today and remove a used switch / lever
Camshaft position sensor, CMPS , CEL code P0340
It is a hall effect sensor used only in the starting sequence
If you unplug it the car will still start but takes more engine revolutions
With the proper adjustment the circle on the internal rotor will line up in the window at # 1 TDC , do you have a elongated biasing Andy Bracket for the CKPS ?
The crankshaft bolt is either a 33 or 34 mm but the fan shroud has to come out for tool clearance
You have the old version of the timing chain tensioner just above the CMPS and a better one was designed by a TSB
03.1-09 (jagrepair.com)
See page 29 figure 3 of the doc below
The sealatic is a leaking O - ring on the installation
See the second Timing doc below
Old Nov 4, 2022 | 08:02 PM
  #125
sturner's Avatar
Man, This car is really starting to confuse me, Now it won't start in park, Microswitch in open condition in park everything boots up normal nothing, but will fire up in neutral
Old Nov 5, 2022 | 03:18 PM
  #126
sturner's Avatar
Replaced Not in Park switch car starts, put console back together and car starts, replaced fan relay module fan turned for a couple seconds now car is dead again, Checked fuses all ok
Old Nov 5, 2022 | 03:29 PM
  #127
Parker 7's Avatar
Something quick and simple on the engine stalling is the power to the Engine ECU
Right engine bay fuse box relay ( ignition positive relay ) can be swapped with the left engine fuse box relay ( horn )
Large ECU controlled relay ( right # 5 ) that must remain closed at all times for the second power to the ECU , this relay is controlled by the ECU and brings power back into the ECU
You can jumper the fuel pump relay to bypass the fuel pump enable to directly power the fuel pump at all times
By powering the fuel pump at all times it will drain the battery after car shutdown with the keys in your pocket
Your power sockets are 3 going to 5 which is the wire leg to the pump motor
Old Nov 5, 2022 | 03:56 PM
  #128
Parker 7's Avatar
Your fan power source fuse # 11 left engine bay fuse box which is hot at all times as the fuse bypasses the corner relay , tis relay bypass accrues inside the fuse box
Only fuse 10 , 12 , 14 , and 16 on all 5 fuse boxes relies on the corner relay to be closed
So if the fans dropped out on you it is a fan control problem
Old Nov 5, 2022 | 04:09 PM
  #129
Parker 7's Avatar
Your fan control relies on the inertia switch to be closed which can be troublesome from reading others
The inertia switch is just fwd of the engine ECU
You can remove the inertia switch connector and jumper between the 2 white wires leaving the 3rd black wire alone
Old Nov 5, 2022 | 04:12 PM
  #130
sturner's Avatar
Swapped relays , fan turned for a moment then stopped , No crank still
Old Nov 5, 2022 | 04:15 PM
  #131
Parker 7's Avatar
try the inertia switch mentioned on later post # 129 above
Old Nov 5, 2022 | 04:25 PM
  #132
Parker 7's Avatar
the inertia switch will shut the engine down and shut the fuel pump off which is the primary safety objective
Old Nov 5, 2022 | 05:51 PM
  #133
sturner's Avatar
Let me backup a moment, After I changed the micro switch on the shifter it started 9 or 10 times, NOW while I was starting it the fan relay module was disconnected, then UPS delivered my new Relay module I connected it turned key to run top fan started turning then stopped and car won't turn over now
Old Nov 5, 2022 | 05:56 PM
  #134
sturner's Avatar
But it will start if I jumper the starter relay circuit, If it was the inertia switch I would think it wouldn't allow to start, Am I wrong?
Old Nov 5, 2022 | 06:06 PM
  #135
sturner's Avatar
And my understanding is it just cuts power to the fuel pump , Car will not turn over at all
Old Nov 5, 2022 | 06:33 PM
  #136
Parker 7's Avatar
There is a connection between the inertia switch not making between the 2 white wires and starter rotation
The inertia switch can be fickle even after you think you reset it by pushing the rubber button , don't take it apart as springs fly everywhere
Mine was involved in a accident with the previous owner and I ended up replacing the inertia switch
Researching with diagram to follow
Old Nov 5, 2022 | 07:10 PM
  #137
Parker 7's Avatar
The ignition positive relay must be commanded closed by a ground path in order that the engine ECU to be powered with fuse # 12
the engine ECU must be powered to be able to provide an agreement / enable ( a secret digital code ) to the BPM so it can provide a ground to close the starter solenoid relay
Old Nov 6, 2022 | 11:35 AM
  #138
sturner's Avatar
I haven't looked it up yet but I'm assuming the inertia switch is under passenger side side panel?
Old Nov 6, 2022 | 11:39 AM
  #139
Parker 7's Avatar
It is always on the right side seat footwell above your right ankle
This is someone's right hand steering model
Old Nov 7, 2022 | 02:13 PM
  #140
sturner's Avatar
Jumpered 2 white wires on inertia switch, Fan turns on and stays on but still no crank,,, Whats the black/green wire do?
