Where can I get my codes scanned?
Old Aug 14, 2011 | 06:10 PM
Canadian_XJ6's Avatar
Default Where can I get my codes scanned?
Hello all,
I just got back from my Canadian Tire and was told that they couldnt scan my car because they don't have a scanner equipped to work on Jags.
Is there a particular place I should go or am I best just buying myself one? If that's the case, where do I find a store that carries them?
I'm just about to replace the plugs in my car and I would like to know if there's a particular cylinder giving me the misfiring issue.
Regards,
Mike
Old Aug 14, 2011 | 09:31 PM
sparkenzap's Avatar
Of course, I was not there and do not know what scanner the fellow had, but any but the most basic scanners will read ISO 9141, which is what the X-300 OBD uses for communication protocal. There might also be some confusion in that MY '95 cars were not required to hace OBDII standard interface. The MY 95 X300 does have it, though. If there is confusion, just tell the scanner it is a MY 96.
Or the guy may just be a lazy so and so. mTry another store or a different shift at his store.
Old Aug 14, 2011 | 09:42 PM
Baby_Jag's Avatar
any scanner works
the person @canadian tire was just being lazy, but anyways they charge something ridiculous like $120 to read a code
just buy a code reader... its a good investment.. anywhere you go is gonna charge you
Old Aug 14, 2011 | 11:18 PM
pan84's Avatar
I have these scanner, Autel VAG405 VW Audi Scanner Code Reader vag 405 obd2 ~ | eBay I bought it for VW, because not every OBD scanner compatible with VW and I did not see car yet, which it can not read, work with jaguar too
Old Aug 15, 2011 | 03:51 AM
Straight6DOHC's Avatar
Does the X300 Jaguar's OBDII system report which cylinder has a missfire? I've had a missfire but I'm not sure I ever found out which cylinder it was. That was with Autoenginuity. I may be wrong, but I didn't think the OBDII on x300 was sophisticated enough to tell which cylinder the missfire is. I'd be glad to be proved wrong.
Old Aug 15, 2011 | 05:28 AM
912guy's Avatar
I use a actron 9175 with freeze frame data and fully updatable...It works great....
Old Aug 15, 2011 | 08:09 AM
pan84's Avatar
yes its tell you which cylinder misfiring, if its not random or multiple misfire
Old Aug 15, 2011 | 12:14 PM
Simprof's Avatar
If your anywhere near Niagara Falls Ontario I'll do it for you. I own a hand held and have one on my laptop as well.. Let me know if I can help.
Old Aug 15, 2011 | 03:08 PM
Many thanks for that information. I had a look at the workshop manuals on DTCs/codes and sure enough there are codes for cylinder misfires. I've had the occasional misfire but never any codes thrown up. How long would it take to throw a code? I know I had a dead spark plug but drove the car for about 30 minutes. No code was shown. Thanks again, every day is a school day....
Old Aug 15, 2011 | 07:25 PM
sparkenzap's Avatar
The X300 is notorious for missing missfires. In fact, I believe my AutoEnginuity reports info on a "consent decree" with the US EPA over this difficiency, or some such warning.
Old Aug 17, 2011 | 07:29 PM
caldercay's Avatar
Are you using the "basic" AutoEnginuity Scan tool or did you add the Enhanced Jaguar Expansion?
Old Aug 18, 2011 | 04:27 AM
I'm using the basic Autoenginuity. I've never had any misfire codes but as said before, have had occasional but definate misfire. I'd considered the Jaguar expansion but as I've a 1995 car, I didn't think it would have given all that more information. I'm happy to hear from other x300 owners who do have the expansion.
Old Aug 18, 2011 | 11:25 AM
Thank you to everyone that has given me so much input, it's nice to know that there is so much help out there from you all. I think I'll have to invest in a scanner since, as Baby_Jag said, its stupidly expensive to get scanned once from these guys.
I did try multiple stores with different shift managers and every time they heard "its a jaguar" is like I told them it was AIDS. They completely changed their tone and said "we dont really service your car at all."
I was told by one of the mechanics that I need an OBD 1.5, whatever that is.
I live in the GTA so I'm hoping that someone, at some place will have a scanner I can buy for cheap. I'm in grad school so I've quite literally got no money, just letters behind my name haha
Does anyone know if this OBD 1.5 is something I should look into or was that guy wrong?
Old Aug 18, 2011 | 01:30 PM
sparkenzap's Avatar
OBD 1.5, huh? I think that idiot is trying to say it is not quite OBDII, which is essential;ly true of the MY 95 X-300 system. It may not FULLY comply with the OBD spec since the spec was still fluid when the system was designed, but it absolutely communicates with the ISO 9141 version of OBD, which almost every Asian car uses. Therefore, I bet most any scanner can do ISO 9141, but surely a guy in grad school can read the scanner specs, right?
Old Aug 18, 2011 | 03:24 PM
imagineaudio's Avatar
I've been considering this:
Bluetooth ODB II scanner
and this app for my android phone:
Torque
thoughts?
Old Aug 18, 2011 | 04:53 PM
caldercay's Avatar
thoughts?
I don't know ... after reading the feedback from David K. Wilson and a couple of others, personally, I would not chance it. A 50% success rate on getting a unit that works all the time - I personally wouldn't chance it. But, then again, that's my opinion.
It might be worth it (since it's only $28USD) to buy one, return if bad, get another, return if bad, until you get a good unit (for someone else)
Old Aug 18, 2011 | 05:07 PM
caldercay's Avatar
Thanks for the feedback.
I checked their website out and liked what I saw. I just wasn't sure I want to dump another $200+ USD for the Jag Expansion ... or if I REALLY needed to.
Maybe start with the base system and upgrade in the future ... I may upgrade to an XK8 ragtop, so it'll be covered.
What I'd REALLY like is a programmer - i.e., to program the ECU/ECM.
Old Aug 19, 2011 | 12:10 PM
Yeah, probably not that particular one, but something like it.
Old Aug 19, 2011 | 02:33 PM
The good thing is, that even the basic set up will perform on any OBDII car and the software from the site continuously updates. Without doubt it will pay for itself quickly if your cars are anything like mine.
I've seen the jaguar enhancement stuff on the website too and believe it states it's a 1996 car? Looks impressive although the feedback I got from another forum wasn't as enthusiastic about it.
FrickenJag
Jun 16, 2025 02:15 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
philwarner
25
Jun 26, 2021 05:43 AM
Keith Carter
16
Sep 29, 2015 12:26 PM
